Old 03-08-2004, 06:57 PM
girlsrace2 girlsrace2 is offline
Send a message via AIM to girlsrace2 Send a message via Yahoo to girlsrace2
ECU Question
What all ecu's will work on my d16z6 swap? Will a pr3 ecu work?
"Just b/c you got a muffler, dont mean you got a hot rod!"- My b/f
"Dont feel bad when a girl beats your ass in a race!"
"Objects in the mirror are losing!"
www.cardomain.com/id/mylilrex.....check this lil hot rod out...lol
Old 03-08-2004, 07:11 PM
What about a P08? The guy says its the jdm equivulant to the p28!
Old 03-09-2004, 10:53 AM
88_SC_CRX_Si 88_SC_CRX_Si is offline
Not sure... however the JDM ECU's may have speed limiter built in. The JDM ZC ECU's, are set to something like 113 mph for top speed (if that matters)...
The P28 is by far the best ECU to use, due to having the proper timing MAP for that engine, rather then the fuel. As most peeps are led to believe...
88' CRX Si - JRSC @ 6psi Z6 Mini-Me, JDM SiR Conversion
NOS #5122, JR Liquid InterCooling System
ZYDNE SECU, 450's
B&M FP Set, B&M Command Flo
AutoMeter - Phantom FP, A/F, N2O, Boost gauges & pods,
ARP HSKit, AEM Pads, 87' HF Drums, DYI CAI
Old 03-09-2004, 12:04 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: ECU Question
yes, you can use a PR3 or a PW0. They are meant for the 1.6 vtec DOHC. Urs is a 1.6 vtec SOHC. But, will you be retaining OBD0 or converting to OBD1? They are both OBD0 and they will have better mapping for ur SOHC, which is the reason alot of people run 90-91 teg ecus for their Si for the better fuel mapping. I say, if you can get a PR3 or a PW0, get it bcuz if you decide not to use it, it can be resold easily.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 03-09-2004, 01:15 PM
91civicDXdude's Avatar
Re: ECU Question
a PR4 map will run a SOHC 1.6L engine *VERY* rich.
so will a PR3/PW0, which will also throw a check engine light for knock sensor, which SOHC engines do not have before 1996.
Old 03-09-2004, 04:12 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
Re: ECU Question
pm6 with vtec controller
p28
thats all i would use
2002 Acura TL Type S
1991 Honda Crx Si
Old 03-10-2004, 09:22 AM
Re: Re: ECU Question
Peeps tend to complain about idling a little too rich, with the 90-91 teg ecus for their Si's. Which can lead to cylinder scuffing, future oil burning, ect... in time.
If all these different ECU's can be used, then why did Honda waste all the time/$$$$ developing them...?
Go here for more info on some of the MAPING for the different ECU's...:
Differances between ECU Maps using EXCELL
http://geocities.com/chipman_13/ecu.html
ZYDNE SECU, 450's
ECU question soul180 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 7 05-29-2004 11:57 AM
dohc zc ecu questions, 89 integra ecu any problems? OneSikCRX '88 - '91 Civic | CRX | Wagon | Shuttlee 2 09-22-2003 08:47 AM
Ecu Question!!! Phat_Si '71-'87 Civic | CRX 9 07-30-2003 10:33 AM
a 96-98 Hatch w/ 3rd gen Integra GSR engine..ECU question XaznPKdogX '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 02-10-2002 03:42 AM
ECU question civicNoS '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 01-17-2002 09:06 PM
