Go Back   Automotive Forums Car Chat > Hyundai > Elantra | Avante
Old 03-07-2004, 06:01 PM
truth truth is offline
Question Hyndai Elantra tranny
If anyone can help.... my appreciation in advance. I have an 97' Hyndai Elantra with a 4 speed automatic with overdrive. My problem: Shifting seems to be erratic. With the slightest increase on gas peddle , it downshifts. Also it seems in 3rd gear with constant peddle presure the rpm lovers .... then goes up about 700 rpm and then seems to shift into 4th gear ok. I changed the fluid and filter and the fluid level is right on the mark but when it is cold it will slip a little going into 3rd gear. Is there a modulator going bad ? I thought the erratic shifting could be the reason I get only 30 mpg but have since learned this is about normal. Anyone got any suggestions / advise ? Thanks ... Howard
Old 11-29-2004, 09:34 AM
snoopydad snoopydad is offline
Re: Hyndai Elantra tranny
I have a 2002 Elantra with 45,000 on it doing the same thing. Took it to dealer, since I had the trans fluid changed there at 30,000. They told me they "topped it off" and it should be fine. Yesterday took it on a trip and did the same thing at highway speeds for about a half hour, then the problem stopped. I"ll probably take it back when I can afford to be without it, but not sure when. If you find out anything, let me know, ok?
Email at [email protected]
buying 2005 Elantra-pls help with these queries fieryari Elantra | Avante 1 09-08-2009 11:21 AM
2008 Elantra Tranny problem base11 Elantra | Avante 1 08-05-2008 07:45 PM
2003 Elantra Tranny service details? n0rt0n Elantra | Avante 2 08-25-2007 07:25 AM
hyndai elantra 2000 check engine signs after change spark plugs loced Elantra | Avante 4 04-15-2005 08:03 PM
'96 Elantra Tranny Blown I think?! lunerslides Elantra | Avante 0 11-12-2003 01:24 PM
