Old 03-07-2004, 03:55 AM
jim300684 jim300684 is offline
running dvc sub parallel on a bridged channel
amp specs:
@4ohm 4x100wrms
@4ohm bridged 2x300wrms
@2ohm 4x150wrms
im new - dunno if this question has been asked -
???? can i bridge a channel and run a single dvc sub in parallel ????
Example:
if i bridge a channel (300wrms p.c), can i then wire a 4ohm(2ohm+2ohm) dvc sub in parallel (to itself) to make a 2ohm load on the amp?
is that possible? if so, what wattage, rms would a bridged channel @2ohm give in this situation?
(I want to bridge 1 channel, and have the other 2 channels @2ohm for 2 speakers to get the extra 50wrms p.c output that a 2 ohm load can give)
thanks
Old 03-07-2004, 09:57 AM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: running dvc sub parallel on a bridged channel
your trying to do too much to a 4 channel amp, they are not made for that. If you just want to use one amp in your system, look into a 5 channel. You will not be able to bridge and run parallel without some serious heat from the amp and most likely blowing it.
www.cloudcity.deviantart.com
Old 03-07-2004, 01:23 PM
SilverJLEclipse SilverJLEclipse is offline
Send a message via AIM to SilverJLEclipse Send a message via Yahoo to SilverJLEclipse
For that amp you need to have the amp "see" a 4ohm load when in bridged mode, running it bridged at 2ohms would most likely send the amp into protection. If you are dealing with a sub that has dual 2ohm vc then you should wire them in Series to acheive the 4ohm needed. Most 4 channel amps can handle a sub considering they have low pass filters and bass boost features.
Good luck finding some 2ohm fronts, the added power (it takes double the power to increase output by 3dB) is really not worth the limited choices versus 4ohm speakers available.
Eclipse CD8053
Kenwood Sirius Satellite
JL Audio XR650CSI (Shopping for something better, suggestions?)
JL Audio 450/4 (Biamped components)
JL Audio 10W7 (2)
JL Audio 500/1 (One for each sub)
Phoenix Gold Powergrid (10 Farad Cap)
1/0 Scosche Wiring
Monster Cable Pro Interconnects
Phoenix Gold Battery terminals
Dynamat Extreme
Old 03-07-2004, 09:15 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
You can't run that sub off of that amp your ohms will be too low in bridged mode and your amp, if not go into protection, will overheat. Can you return the sub and get a dual 4ohm? you could run each vc to each channel on the mp, but you have to make sure that you have a mono signal comming through b/c your vc's have to get the exact same signal. A better option would to get an amp (2 ch. or mono) that gives you your desired wattage at either 1 ohm (parrallel) or 4 ohms (series). I would reccomend getting a new amp over getting a new sub and running each coil to each channel b/c its too easy to mess your sub up.
Old 03-07-2004, 11:35 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Re: running dvc sub parallel on a bridged channel
that amp will work fine
Wire the coils in series to a 4ohm load, bridge 2 of the channels and hook the sub to it. The sub will get 300rms off of the rear 2 channels bridged, and then you have the front 2 channels powering your front speakers.
Forget about getting some 2ohm components though, that will cut out probably 99.9% of all the speakers out there, you will only be left with a very very very limited selection. Screw the extra 50rms and get a set of speakers that will make you happy.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
2ohms from mono amp to dvc sub? justav6 Car Audio 6 06-25-2009 07:02 PM
Problem wiring 4 DVC subs, please help!!! Chevy Power 06 Car Audio 16 12-14-2007 06:49 PM
2ohm dvc sub Tonglebeak Car Audio 16 09-10-2007 05:17 PM
DVC Subs on a Mono amp. MStout Car Audio 3 08-11-2004 12:04 AM
Wiring Dvc Subs aaron1976 Car Audio 1 05-21-2003 08:04 AM
