Old 08-10-2004, 03:21 PM
MStout's Avatar
MStout MStout is offline
DVC Subs on a Mono amp.
Ive been sitting here confused about how to match Dual Voice Coils with one amp...on 2 subs I mean. Im planning on getting a Alpine Tpe-X which is Dual 4 ohm coils...whereas a Type-R is the same thing, except one of those couldnt handle my 1501D so I would of course get 2. My question is if you have 4 coils to run (2 subs x 2 coils) and theyre all 4 ohm...would I be able to run it off of a 1100x1 at 2 ohm amp? I wouldnt think that you would be a separate amp just cause the sub has 2 voice coils. And another question...what would work with a Dual 2 ohm sub...unless thats what I would need to get for this to be able to work. Thanks.
Old 08-10-2004, 04:25 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Re: DVC Subs on a Mono amp.
With Dual 4 ohm you can run 1 ohm (parallel), 4 ohm (parallel/series), and 16 ohm (series). With Dual 2 ohm you can run .5 ohm (paralell), 2 ohm (parallel/series), and 8 ohm (series).
Old 08-10-2004, 07:25 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
correct, so if you got the dual 4ohm subs, you could not use that 1100x1 @ 2ohm amp (well you could, but you'd have to run it at 4ohm and get 550x1 instead). You would need either a 1ohm stable mono amp or a very powerful 2ch amp. If you got the dual 2ohm version then you would need a 2ohm stable mono amp.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 08-11-2004, 12:04 AM
MStout's Avatar
Ahh that sucks...but thats what I thought...Thanks.
