Old 03-03-2004, 11:47 AM
MakaveliThaDon07 MakaveliThaDon07 is offline
Send a message via AIM to MakaveliThaDon07 Send a message via Yahoo to MakaveliThaDon07
subs and amp questions
hey im new here. i was just wonderin if anyone knew which is better JL Audio w4 or w6?? this would help me out alot. also if i have 2 12" JL Audio subs which amp would be the best to run these to get max bass and should i use a single or multi channel amp?? if someone could please tell me id really appreciate it. thanks alot
Old 03-03-2004, 09:32 PM
EG_Civic's Avatar
EG_Civic EG_Civic is offline
I havent a clue which JL sub is better, Im not real familiar with Jl Audio. Anyways to get the most bass, find the RMS load for the subs(how much constant wattage they can take) and get close to that for your amps RMS. I would run mono amps because if the RMS load is higher on the subs youll need a big amp to get close to that wattage. Also find out whether the subs are designed for a ported, bandpass, or sealed box. If its a sealed box and your tight on space you can stuff the box with polyfill(that stuff in the sewing section that they put in pillows) and make the sub act as if the box is bigger. One more thing they say smaller boxes give "tighter" bass and bigger boxes give bass with more "thump". I prefer tighter bass, the kind that makes the hair on you arm dance whenever it hits. Just my thoughts.
Hope that makes sense.
EDIT: If you used a multi-channel amp you could wire your subs in 2 ohm and get more power, but Im not a big fan of doing that. Thats just me though
Old 03-03-2004, 10:27 PM
Phat_Jax's Avatar
Phat_Jax Phat_Jax is offline
Send a message via ICQ to Phat_Jax
w6 is better...
The w4 has been discontinued for YEARS now, I can't believe you found one... lol
The w4 was a poor design, but the w6 is one of the best small-enclosure sound quality subs I've ever heard.
I've owned a few of those in my day.
Actually, I'm running the w6 version 2's right now in my 'Lude
Sub and Amp Question doberman_52 Car Audio 8 02-07-2008 05:21 PM
question on subs and amp???????????? hotshyt Car Audio 1 11-08-2006 08:09 AM
question about sub and amp Tlo Car Audio 3 10-04-2005 07:56 PM
sub and amp question XxslayerxX Car Audio 1 03-19-2003 01:31 PM
