Old 10-03-2005, 09:34 PM
Tlo Tlo is offline
question about sub and amp
i was wondering if i were to get 2 P112S4 12" subwoofers will i have to put them on 2 different channels on an amp or can i make it fit on one channel.
Old 10-03-2005, 10:07 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: question about sub and amp
I'm guessing the S4 in the model number stands for single 4, in which case you could wire them together in parallel for a single 2ohm load, then use an amp that gave you whatever power you wanted at 2ohm. For example, if each sub wanted 100rms, then you would get a 200x1 @ 2ohm amp.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 10-04-2005, 07:56 PM
Johannes Johannes is offline
Banned
Yes it does
P = Punch
1 = Stage 1
12 = 12" in size
S = Single voice coil
4 = 4 ohms
Banned
Yes it does
P = Punch
1 = Stage 1
12 = 12" in size
4 = 4 ohms
