Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-03-2004, 01:29 AM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
b18c rebuild
has anyone here rebuilt a b18c jdm engine to be able to handle turbo? if so how hard was it to do and what did you spend on parts and such?
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 03-03-2004, 02:51 PM
SP_Mark SP_Mark is offline
Re: b18c rebuild
It depends how much power you are looking to make?? If you want to go full turbo/race i would recommend that you put some aftermarket low compression pistons and stronger aftermarket rods. The motor stock can handle a turbo kit at low and mid boost ranges. Turbonetics make a great kit and does Greddy. I can get either kit for you at reasonable prices. Let me know or send me an e-mail if you want more information. Good Luck !!
Mark @ SP ENGINEERING
www.sp-power.com
Old 03-03-2004, 05:00 PM
DeleriousZ's Avatar
Re: b18c rebuild
i'm looking at running around 15 psi on all new internals for a daily driver, may sound a bit excessive... but i'm just that kinda person. 300 whp is my goal, and downtime doesn't really matter because i'm going to keep my current stock engine in until i completely finish the rebuild.
Old 03-04-2004, 12:52 PM
18c5sol94 18c5sol94 is offline
Re: Re: b18c rebuild
I HAVE A JDM 18C IN A DEL SOL AND PLANNING ON ADDING A TURBO I HAVE DONE SOME STUDYING. MOST OF MY INFO I GOT FROM ITRCA.COM THERE ARE GUYS ON THERE RUNNING 15 PSI ON DAILY DRIVER WITH STOCK INTERNALS. THEY ALL SAY TO GET INLINE FOUR HEAD GASKETS AND BLOCK GUARD. ON A GOOD TUNE IT IS POSSIBLE.
Old 03-04-2004, 05:29 PM
DeleriousZ's Avatar
Re: b18c rebuild
really... that's it eh... i dunno about stock internals.. but maybe i won't have to do any sleeving?
Old 03-04-2004, 05:37 PM
i did not believe it either. dude just check out itrca.com and look at the forced induction sections ask them they will tell you there are a few cats running 15 psi on stock internals daily driven with head gasket, honda data and block guard on a good tune. i myself would not run 15 psi on daily driven but hey 10 is not bad. check it out the you will believe me
Old 03-04-2004, 05:52 PM
http://home.comcast.net/~jniemi1970/senseidyno6.mpg
_________________
12.792 at 114.85mph (untuned) 2000 ITR stock internals
295.6whp@8500rpm- on Mustang MD Dyno -Hondata tuned by Payn Tech...Thanks Tom!
188.9torq@8000rpm
Gears in my head, gasoline in my veins...life is good!
there you go i found a video of it to
94 Ranger Tranny rebuild freakyfire05 Ranger | Courier 0 09-11-2010 04:11 PM
2000 z71, 5.3 budget rebuild, any tips nthnkng33 General Discussion 2 07-20-2010 10:06 PM
4R55E tranny rebuild problem mrstubb Explorer | Explorer Sport Trac 1 05-30-2010 11:27 PM
1994 f150 5.0 rebuild spoovey F Series 4 03-19-2010 07:30 PM
Engine Rebuild abc234 Aveo 1 05-17-2009 07:38 PM
