Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 07-18-2010, 03:49 AM
nthnkng33 nthnkng33 is offline
2000 z71, 5.3 budget rebuild, any tips
I have a 2000 silverado with the 5.3 liter. It has 297000 miles. It runs ok but I want to rebuild it before it does get bad. With that many miles, is it a good idea to rebuild it or should I invest in a used engine? I'm having to do this on a budget. So if rebuilding it is ok, how is tje cheapest way to do it and it still be a good job?
Old 07-18-2010, 10:41 AM
GuyFromRI GuyFromRI is offline
Send a message via AIM to GuyFromRI
Smile Re: 2000 z71, 5.3 budget rebuild, any tips
The problem is, if you buy a used engine, you don't know 100% what your getting. Was the oil only changed twice? Did they overheat it to the point that it didn't cause any "permenant damage" but something is off just enough to cause an issue in 20k miles? The point is, if you buy a used a motor, you may end up having to rebuild it anyway. I don't know your budget but from my experience, a "good" used motor is about $800(up this way) and if the scrap yard offers a warranty on it, you have to do some work before starting it. I bought a used motor once and had to do the following for the 30 day warranty to be valid;
1. Cap, rotor, wires, plugs
2. Head gasket
3. Oil change(obvious either way but on the list)
4. Certain other gaskets
5. And there are about 5 or 6 other things I can't even think of right now but it wasn't a cheap list.
My recommendation, if you have a good foundation, work with that. Pull it, flush it, decide what you want to change and do it. If you get brazen, some new pistons, rings and rods, maybe have the head checked (only 50 to have it tested) and some new externals(radiator, high mileage oil filter, so on). Either way, definitely worth the rebuild.
Happy chevy-ing!
Old 07-20-2010, 09:06 PM
j cAT j cAT is offline
If you have maintained this for its life so far and with the current mileage it would be better to rebuild this engine,,,wear is all about oil and filters...damaged engine parts from excessive heat and coolant system abuse..sounds like you did a very good job with this vehicle..
when you replace the head gaskets you must use new bolts...
replace items like O2 sensor and the other sensors as they do not last forever..maf/crank/cam / ECT sensors
starter motor, alternator and water pump..
Tags
chevy , engine , rebuild , z71
