Old 02-27-2004, 08:03 PM
215mar 215mar is offline
Question Rear End Gear Ratio
I'm wondering if there is any way to identify the rear end gear ratio on my 2002 ????
Old 02-27-2004, 09:34 PM
slacker_53's Avatar
slacker_53 slacker_53 is offline
Re: Rear End Gear Ratio
The gear ratios your truck is running will be on the sticker in your glovebox in the form of a number code. All the option and assembly codes of your truck are found on this sticker. The differential code is usually found on the second line of the sticker just to the right of center, but not always.
Look for a code usually beginning with the letter 'G'.
GT4 is for the ratio 3:73 which is standard for the Z71 option. GT5 and GT8 are 4:10. GU6 is 3:42.
Hope this helps.
-slacker
When I die, I want to die peacefully in my sleep, just like my grandfather................not yelling and screaming like the other people in his car!
http://www.geocities.com/tbuckit1/index.html
1975 Caprice rear end gear/rear end swap? Topless75 Caprice 3 03-10-2010 01:29 PM
Replacing rear end gears bigdaddyhill71 General Discussion 1 02-10-2010 10:10 AM
Rear End Gear Ratio on 97 Seirra newh68ss Sierra 3 10-16-2004 02:26 PM
Rear End Gear Ratio 215mar Sierra 2 02-29-2004 10:05 PM
rear end gear ratio galaxie500fb Mustang Talk 6 02-14-2004 04:42 PM
