Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 02-27-2004, 06:52 PM
215mar 215mar is offline
Question Rear End Gear Ratio
I'm wondering if there is any way to identify the rear end gear ratio on my 2002 Sierra????
Old 02-29-2004, 03:40 PM
juma33 juma33 is offline
look over on the silverado board...someone just gave this info. the spid codes in glove compartment door list the code. a gu8 is a 3.42. don't know about the others but someone listed and identified them over on that silverado board.
juma
Old 02-29-2004, 09:05 PM
jdod85 jdod85 is offline
Send a message via AIM to jdod85
Re: Rear End Gear Ratio
The gear ratios your truck is running will be on the sticker in your glovebox in the form of a number code. All the option and assembly codes of your truck are found on this sticker. The differential code is usually found on the second line of the sticker just to the right of center, but not always.
Look for a code usually beginning with the letter 'G'.
GT4 is for the ratio 3:73 which is standard for the Z71 option. GT5 and GT8 are 4:10. GU6 is 3:42.
jim
1975 Caprice rear end gear/rear end swap? Topless75 Caprice 3 03-10-2010 12:29 PM
Replacing rear end gears bigdaddyhill71 General Discussion 1 02-10-2010 09:10 AM
Rear End Gear Ratio on 97 Seirra newh68ss Sierra 3 10-16-2004 01:26 PM
Rear End Gear Ratio 215mar C/K 1 02-27-2004 08:34 PM
rear end gear ratio galaxie500fb Mustang Talk 6 02-14-2004 03:42 PM
