Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 09-19-2004, 12:45 PM
newh68ss newh68ss is offline
Question Rear End Gear Ratio on 97 Seirra
Hello,I am new to this ,but i have a 97 gmc seirra 4x4 with 373. gears and the rear end is going .i went to my local gmc dealer and i told him my vin number and he told me what my gear ratio number was .doe's any one know where i can get that info with out taking off the basket cover on the rear end .or how i can tell by reading the vin.what number to look for that would tell me that the truck would have the same ratio is to what i have .thank you in invance for any and all help.geno
Old 09-23-2004, 08:07 AM
Jeremy-WI Jeremy-WI is offline
Re: Rear End Gear Ratio on 97 Seirra
There is a sticker inside your glove box with the RPO codes, you should find a GT4 on it. GT4 is the RPO code for the 373 gear ratio and any vehicle made with that gear ratio should have that code
Old 10-07-2004, 11:20 AM
sudsy49 sudsy49 is offline
Any time you don't know your gear ratio, an easy way to find out is to jack up the truck and turn the rear wheel one complete turn, have a buddy count the # of turns the driveshaft turns around and that is your axle ratio. Remember, if your truck is non- posi, make sure both rear wheels turn together or the differential will give you a false reading!
Old 10-16-2004, 01:26 PM
slacker_53's Avatar
slacker_53 slacker_53 is offline
Check your glovebox for the build sticker.
GT4 3:73
GT5 4:10
GT7 3:33
GT8 4:10
GU2 2:73
GU4 3:08
GU5 3:23
GU6 3:42
GV2 5:83
HC4 4:56
HF8 4:88
GN9 4:11
GH0 3:54
GK9 4:63
GL3 6:17
GM1 2:59
GM3 3:45
GM8 2:56
Your Ratio should be located somewhere right of center about the second or third row down from the top and most of the time begins with a 'G'. Your truck should either be a GT4 or GT5.
-slacker
When I die, I want to die peacefully in my sleep, just like my grandfather................not yelling and screaming like the other people in his car!
http://www.geocities.com/tbuckit1/index.html
