Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 02-27-2004, 01:45 PM
ecumatt ecumatt is offline
Send a message via AIM to ecumatt
b16 wont start
Drove my newly swaped jdm b16 91 hatch up to school. On the way up it shut off twice and wouldnt idle without wanting to cut off. I figured it was becuase the engine had not been run in several months. When i got it to school i parked it and came back the next day and it wouldnt start. It should be getting fuel and should be getting spark. has new battery. Doesnt want to turn over. dont know what could be wrong? someone have an idea?
Old 02-27-2004, 05:36 PM
94civic's Avatar
94civic 94civic is offline
it sounds like your alternator went out.
1994 civic ex - b16a sir2 w/lsd
too much to list
http://www.cardomain.com/memberpage/423478
Old 03-01-2004, 03:37 PM
zebra123 zebra123 is offline
Re: b16 wont start
did you leave your new battery sitting around on a concrete garage floor for any length of time, before the swap...? I hear that'll discharge a battery altho since I don't store my spares that way, I don't know personally.. It could be it wasn't 100% charged and the 2-3 times you started it when it stalled killed it the rest of the way. Even w/o an alternator a charged battery can start and run the car several times,no problem...
Check ALL your battery connections and verify they are clean and still tight (I mean including the ground termination, the positive lead to the starter motor, etc... ) If your battery is still charged, it ought to crank at this point (assuming a good starter motor, also). Try jumping it with a known good battery after verifying connections, if it cranks yours is low/dead/maybe no good.
Once its running...
Did your car EVER run right, post-swap ? Hopefully you get some expert assistance in chasing down the problem. I mean in the carbuerated engine days, 'poor idle' was often times as simple as a vacuum leak, someplace...
PEace,
Z
1991 wont start..motor from 1985 no spark HELP rwoodxtreme C/K 4 01-31-2010 10:19 AM
94 honda cranks but wont start help please supermikeq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-19-2009 06:00 PM
97 yukon wont start yukon45427 Yukon 1 06-23-2009 07:24 AM
87 jimmy wont start Chevygirl04 Problem Diagnosis 1 04-09-2009 06:44 PM
03 Eclipse rs wont start mrcontreras Eclipse 2000+ 1 02-27-2009 05:49 PM
