Old 01-31-2010, 08:00 AM
rwoodxtreme rwoodxtreme is offline
Question 1991 wont start..motor from 1985 no spark HELP
Just got a truck, i drove it home and pulled it in the garage. changed all the spark plugs and wires one at a time, and degreased the engine. now it wont start. the distributor isnt wet, i went to advance auto and had the ignition control module tested. it has an accel super coil on it. no idea how many wires or how to test to see if its getting power. any ideas?
Old 01-31-2010, 08:52 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 1991 wont start..motor from 1985 no spark HELP
Wires crossed?
Got good spark to all plugs?
Got fuel pressure?
MT
Old 01-31-2010, 08:53 AM
MT-2500's Avatar
AF - Advisor
Wires crossed?
Can you hear fuel pump run on key on 2 second prime up?
Got fuel pressure?
Engine cranking good?
MT
Old 01-31-2010, 08:55 AM
no spark at all to the plugs..manual fuel pump. took wires off and replaced them one at a time so i wouldnt cross them.
Old 01-31-2010, 10:19 AM
MT-2500's Avatar
AF - Advisor
What dist and carb does it have?
Any spark at coil?
Is dist turning when cranking?
If running before you worked on it?
go over what you did to it.
Did you knock off any wires.
MT
Tags
1991 , problem , start , starting , won't
