Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 06-23-2009, 05:31 AM
yukon45427 yukon45427 is offline
97 yukon wont start
i haxe a 97 yukon it started cutting out on me at first when it gets warmed up then this mornin wont start at all i have drove it that way for a month or so. i have changed the coil pickup and the fuel filter and fuel pump 2 times then the computer and the fuel pump regulator. i took the truck to auto zone to have them run a code check on it and it sead a oxegen sencer was bad on the bank one so he told me to change one from the passengers side to the drivers side so i did that and had codes on both sides then. got up drove it home and parked it and now it wont start. any help with this thing would be greatly appreciated thanks in advance,if you need to call me for more info my # 937-551-3074 this is my only car and need to get it fixed fast before i loose my job
Old 06-23-2009, 07:24 AM
Question Re: 97 yukon wont start
i replaced the coil this mornin with a coil i had laying around and it storted up but i found on the coil that it was burnt with a small pin hole in it and if you move the coil around it would start up will this make it start cutting out when it gets hot and does the coil have to be grounded when you try to start it it wont start again right now but going after a plug wire set today and bolt this other coil down thanks for your help
Tags
problem , start , starting , yukon
