Old 02-26-2004, 02:15 PM
lantzjul lantzjul is offline
Unhappy Minivan bottoming out
I have a 1992 Plymouth Grand Voyager with 180K miles. I recently replaced the struts but the vehicle still bottoms on minor bumps. Any experience out there as to whether the coil springs need replacement or is it more likely the struct mounts are worn out?
Old 02-29-2004, 01:25 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
You need new springs for sure.
Old 04-25-2004, 10:14 PM
goinbig goinbig is offline
Send a message via AIM to goinbig
Re: Minivan bottoming out
check the shocks first
Old 05-17-2004, 08:40 AM
slantsixness's Avatar
slantsixness slantsixness is offline
when you say bottoming out, are you just talking about the clunk in the front end when you go over a bump?
If that's what it is, then check your sway bar bushings and mounting points. They all make these noises.
If I knew what I did to break it, I would've known not to do what I did.
www.classicwinnebago.com
Old 05-20-2004, 08:27 PM
No More Bottoming
thanks for the input...It definitely was the springs. The OEM design was far to wimpy. I replaced with the recommended replacement springs, which were beefier. Also replace the strut mounts while I was at it. Works great. I knew it wasn't the struts as those had been replace 18 months ago and they are still okay.
2" drop and Im bottoming out!! help plz fyrewyre819 Accord/TSX/Accord Hybrid 7 02-10-2004 03:39 PM
bottoming out and scraping soudns in new suspension Jay eS Iye '88 - '91 Civic | CRX | Wagon | Shuttlee 7 01-22-2004 09:46 PM
Idle bottoming out keller3 Off-Topic 6 07-10-2003 07:21 PM
92 Accord EX dropped 2 inches and is either hitting bump stop or bottoming out! no2morrow Accord/TSX/Accord Hybrid 13 02-26-2003 08:15 PM
Is bottoming out a problem with a lowered Maxima? Shayyadin Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 9 05-13-2001 12:18 PM
