Old 06-10-2003, 02:47 PM
keller3 keller3 is offline
Idle bottoming out
problem with a 91 AWD turbo. i have read a lot about problems concerning high idles, but my problem is that it cuts out sometimes. not every time i start the car, but most often when it does happen it is after i haved turned the key over and it comes back down to idle . . . cuts right out . . . sometimes after backing up. i dont think its related to a clutch problem because it will cut out even when ive thrown it in neutral and try to let it idle that way. any suggestions? it happens in both cold and warm weather. after the car has been running for a few miles though it almost never cuts out. usually when just starting it up. just changed plugs, wires, air filter, fuel filter, pcv valve.
Old 06-10-2003, 09:31 PM
pcv pcv is offline
Check the coolant sensor, make sure the connections are good and clean the throtle plate with a good cleaner.
NOTHING LIKE AN OLD CAR.
Old 06-22-2003, 03:50 PM
Talon007's Avatar
Talon007 Talon007 is offline
Send a message via MSN to Talon007
If its not the coolant sensor, check the ISC motor
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
Old 07-10-2003, 06:03 AM
kjewer1 kjewer1 is offline
AF - Advisor
Could be ISC as talon007 said. Usually that will give you more obvious issues and it will do it all the time. Is the FIAV (fast idle air valve) working? (is idle higher when cold) Try dissconnecting the battery, waiting a few mintues, then reconnecting. This will force the ECU to reinitialize the ISC. Since its an open loop stepper (no feedback/encoder to relay its position) it can sometimes become out of synch with the ECU. After the car is running for a bit the ECU will learn where to put it, but on startup it assumes its centered, so I wonder if this could cause your problem. Try it out, since its so simple to reset the ECU anyway.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-10-2003, 08:01 AM
Dream_Tsi Dream_Tsi is offline
Send a message via ICQ to Dream_Tsi
hrm
I'm having idling problems as well; GSX Racer, maybe you could help? My bird idles like I have really lumpy cams. It idles normal but "hunts" betweent 600-700 rpms without stalling. I can run a/c and drive the car normally and it doesn't do this all the time...should I just replace the isc motor? Is there anything else it could be?
Old 07-10-2003, 05:16 PM
AF - Advisor
For those symptoms I would check for intake leaks first. See the leak tester vfaq at www.vfaq.com. Cost 10 bucks, and takes a few minutes. The bad ISC will usually rev much higher when its surging...
Kevin Jewer
Old 07-10-2003, 07:21 PM
I'm going to make a trip up to home depot to get the parts this weekend. I'm also going to get a can of carb cleaner and spray the crap outta the isc motor- that might work, at the very least I can prolong its lifespan. My coolant light stayed on for a split second this morning, now I have to check the sensor. God help me when I start modding this car
Oil prssure bottoms out while at idle masonc87 Grand Cherokee | Grand Cherokee SRT8 2 09-21-2007 08:49 AM
2" drop and Im bottoming out!! help plz fyrewyre819 Accord/TSX/Accord Hybrid 7 02-10-2004 03:39 PM
bottoming out and scraping soudns in new suspension Jay eS Iye '88 - '91 Civic | CRX | Wagon | Shuttlee 7 01-22-2004 09:46 PM
92 Accord EX dropped 2 inches and is either hitting bump stop or bottoming out! no2morrow Accord/TSX/Accord Hybrid 13 02-26-2003 08:15 PM
Is bottoming out a problem with a lowered Maxima? Shayyadin Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 9 05-13-2001 12:18 PM
