Old 01-06-2004, 04:35 PM
Jay eS Iye's Avatar
Jay eS Iye Jay eS Iye is offline
Send a message via AIM to Jay eS Iye
bottoming out and scraping soudns in new suspension
i installed my tokico hp shocks and tokico high performance springs 1.25-1.5 inch drop but i'm having a couple problems. when i push down on the car on the rear driver's side i get a kind of scraping squeeking sound, when i do the driver's front i get the same only not as bad. also when i'm driving, the passenger front bottoms out sometimes, and i think the rear is doing it to, but it could just be the crap in my trunk jumping around.
i still have yet however to get an alignment b/c i have to replace my tie rods and i'm doing the ball joints and axles wtih them. and the wheels are offset right now; they are both pushed back in the wheel well and the driver's side is somewhat cocked out at the bottom. so that may solve it but i don't know, any suggestions?
The Civic is gone...
The Camry never ran...
The Chevy is here to stay...
The Ultimate Honda Engine
Old 01-12-2004, 09:17 AM
feelsfast feelsfast is offline
Send a message via AIM to feelsfast
Re: bottoming out and scraping soudns in new suspension
I didn't think it was necessary to do this for a minor drop but did you cut your bumpstops. Get that alignment done and get those parts changed its only gonna cause you more problems in the future. Tire wear, more worn parts etc.
Yes my car is slow!
Old 01-12-2004, 10:59 AM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
Are you sure you put the right springs in the right places? If you have the rear spring in the front then the weight may cause it to bottom out if it's not stron enough.
Check out my car here My 91 Hatch
Old 01-12-2004, 12:06 PM
spongerlbc's Avatar
spongerlbc spongerlbc is offline
Send a message via AIM to spongerlbc
The scraping sound could also be your suspension bushings squeeking more than they used to. When I first lowered my car 2.5" on Suspension Technique springs with Koni Yellows and backed out my driveway over the curb thing I thought I had killed my suspension but it was just the 13 year old rubber bushings. The bottoming out sounds like what Feelfast suggested....did you cut your bumpstops? How hard are you hitting bumps when you bottom out?
DOHC ZC 89 DX HATCH
Old 01-20-2004, 09:57 AM
Jay eS Iye's Avatar
i did cut my bump stops, cut them in half. i don't have to go very fast for them to bottom out, even like 5-10 mph. i also kinda feel and hear some squeeking when i go around turns quickly. i just expected my ride to feel better changing out my old ass shocks and it feels the same if not worse. oh and the bottoming out affects the back more than the front.
Old 01-20-2004, 10:01 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
by chance, does it sound like stuffs flying up and down in ur hatch when it bottoms out? mine does that when it hit bumps, could be the suspension being stiff, might need to be broken in a bit
Old 01-22-2004, 10:04 AM
Jay eS Iye's Avatar
i kinda hear what sounds to be stuff moving in my trunk, but i figured it was loose stuff in my trunk... so could it just need to be broken in, and then it will stop bottoming out?
Old 01-22-2004, 09:46 PM
1PhatCX's Avatar
yea i think it may just hafta be broken in by the sounds of it, its not bottoming out tho, its just really stiff shocks and springs probly
Koni reds and skunk2's bottoming out!!!!! Nackattack Wheels/Tires/Suspension 12 06-12-2005 04:54 PM
2" drop and Im bottoming out!! help plz fyrewyre819 Accord/TSX/Accord Hybrid 7 02-10-2004 03:39 PM
2" drop on 95 accord and bottoming out help!!! fyrewyre819 Interior | Audio | Security 8 02-09-2004 01:37 PM
HOTCHKIS new suspension and Energy Suspension parts for sale ALL NEW IN BOXES!!! Mackzero El Camino 1 01-25-2004 02:58 PM
92 Accord EX dropped 2 inches and is either hitting bump stop or bottoming out! no2morrow Accord/TSX/Accord Hybrid 13 02-26-2003 08:15 PM
