Go Back   Automotive Forums Car Chat > Mercury > Villager
Old 02-26-2004, 07:11 AM
Tech_n's Avatar
Tech_n Tech_n is offline
Turn Signals does Not Work
When I turn the hazard lights on, the lights all around and
on the car comes on and then when I clicked the turn signals up and down the lights
doesn't seem to work. I checked the flasher, that wasn't the problem,
and I replaced the combination switch and that wasn't the problem
either, therefore I wanted to know if you had any idea what it could be?
Also, I wanted to know if you had an electrical Diagram for the 96"
Mercury Villanger, if so could you e-mail me a copy? On the other
hand, I wanted to know how many flashers do this car have and where
would they be located?
Old 02-26-2004, 12:27 PM
JEEPMAN33 JEEPMAN33 is offline
Re: Turn Signals does Not Work
Hey Tech N,
If I were you i would go here http://cgi.ebay.com/ebaymotors/ws/eB...category=34228
There on Ebay I bought a complete service manual on CD for $9.00 + shipping. Worked great for me!
Old 06-21-2004, 03:08 PM
givemebreak givemebreak is offline
Send a message via ICQ to givemebreak Send a message via AIM to givemebreak Send a message via MSN to givemebreak
Have you checked all the turn signal bulbs?
One of mine in the rear with a dual filament bulb that was crossed and cause all
sorts of strange turn/brake/parking light issues...
Once i changed that bad bulb...all was better!
It seemed that one filament over heated/worn out...and drooped on to the other....causing a short.
Old 07-22-2008, 09:50 AM
jmadnick jmadnick is offline
Hi,
Check the HAZARD SWITCH! Sounds weird but all power for the turn signals runs through the hazard switch. Mine was worn internally. I fixed it by cleaning the connections inside the switch. You can short across the switch to test it.
JLM
turn signal lights not working x3mtm Durango 4 01-11-2010 12:49 PM
Turn Signal Does Not Work at All at1212b Caprice 7 10-13-2007 02:39 AM
1996 sebring convertible right rear turn signal does not flash berko70 Sebring | Sebring Coupe | Convertible 3 01-03-2007 12:46 PM
turn signals/hazard not working-help! jc83 Grand Prix 3 04-03-2004 08:24 PM
Turn signals/Directionals not working correctly Chanticleer Engineering/ Technical 1 02-10-2004 05:01 PM
