Old 03-31-2004, 10:34 PM
jc83 jc83 is offline
turn signals/hazard not working-help!
1st time for me!! yup im a newbe!--anyhow..ive got a 94 grand prix se and the alternator started going south, so i replaced that made the idiot light for the battery symbol go away... but i now am having an issue with the turn signals/flashers not working..my mechanic neighbor helped on the alternator told me it might be a problem inside the steering column after we checked ALL of the fuses of which none were bad...so i put this to all you pontiac whizkids..is there any other fuses in my car up under the dash? or am i going to have to gutt the steering column to get at the turn signal switch box..thanx for any help you send and i gotta say this site is awesome very informative! you guys rock!
Old 03-31-2004, 10:48 PM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
Re: turn signals/hazard not working-help!
Well, in the manual for my 98 it says to check for a bad ground and if thats not it then replace switch.
That probably doesnt help to much for your 94.
Old 04-03-2004, 11:58 AM
if i buy the part new it costs anywhere between 70-100$..so i went to the junkyard and got a switch assembly...looking at the inside of this unit makes me wonder if i can just spray some kind of degreasing fluid inside will it help? still you would think that flipping the switch up and down fast that i would get some kind of juice flowing but it is still dead as a rock..i will go looking for a short or something before i rip apart the steering wheel..i did try wiggling wires and still no luck but thanx for the input anyone else ever experience this???
Old 04-03-2004, 08:24 PM
i3o2Matt's Avatar
i3o2Matt i3o2Matt is offline
Send a message via AIM to i3o2Matt Send a message via Yahoo to i3o2Matt
yea my turn signal switch is startin to go bad...that sounds like what's happenin 2 mine...i need to manually blink the right turn signal and the left is like i have to push it down then rotate it...i kno...i need to replace it...
