Old 02-20-2004, 02:01 PM
jamesjeg1214 jamesjeg1214 is offline
96 windstar rear door
Does anyone know how to take the back door apart on a 96 windstar?
Old 02-21-2004, 09:33 PM
tarheel4eva tarheel4eva is offline
Send a message via Yahoo to tarheel4eva
i have a 97 and i have removed the back door on my van, and found the sensors but wasnt able to have time 2 clean it. iwas wondering if ne1 knows if it's the sensor with the electrical connection attached on either side of the door? The removal was easy with the rear door. I removed teh back panel with a pair of long needle nose pliers. You would have to pull the tabs with the section of the panel to prevent damage of the tab placement holders. There were about 13-15 i believe. then i had to remove one panel tabs on each side of the upper rear door panel to be able to remove the lower panel. then you would have to slide the panel to get the rear latch through the hole. then the assembly is in reverse. Hope this helps. I going to go remove the panel tomorrow and clean those contacts!
Rear Doors Won't Open bdzb1234 Econoline 2 05-06-2010 11:34 PM
Rear Door Again - How to open with broken door handle larch303 M Bodies 1 03-26-2006 03:48 PM
1995 4 door, front / rear door panel removal jbandsj Blazer 1 08-23-2004 05:18 PM
door adjar - wd40 where in rear door peter63north Windstar 3 07-09-2004 11:50 PM
NEED HELP!! 98 Windstar rear sliding door Power lock failure irobbig Windstar 2 07-05-2004 07:06 PM
