Go Back   Automotive Forums Car Chat > Ford > Econoline
Old 05-05-2010, 11:26 PM
bdzb1234 bdzb1234 is offline
Rear Doors Won't Open
About two weeks ago, I discovered that the right rear door would not open from the outside. I was able to open it from the inside, but as of tonight I can't open it at all. The Left rear door opens fine once the right is open.
When I pull on the door latch, it feels loose like it's not catching on the inside of the door.
Anyone have any ideas of how to get the doors open?
Old 05-06-2010, 10:10 PM
Re: Rear Doors Won't Open
If anyone else runs into this problem, here is the fix I discovered with my neighbor:
The cables inside the doors have plastic grommets on the ends which help hold the cables into place on the latches. The grommets cracked off due to wear and age so the cables were no longer connected.
After pulling the inside door panels off, we were able to pull the cable which attaches to the inside latch through the hole under the latch. This is a temporary fix which allows me to open the door from the inside only by pulling gently on the cable.
I have to get replacement cables (probably from dealer) and replace the cables. Should be easy once I remove the rear license plate holder.
So find the cable and pull on it gently to open the door, then replace the cables.
Old 05-06-2010, 10:34 PM
Scrapper Scrapper is offline
AF Premium User
he's prety much dead on on cables and the plastic grommets wearing out.
Tags
door , doors , e-150 , econoline
