Old 02-12-2004, 07:37 PM
speedindevil's Avatar
speedindevil speedindevil is offline
Send a message via AIM to speedindevil Send a message via Yahoo to speedindevil
Question Airbag light on after plug wire change???
My stepfather has a 1998 S-10 with a 2.2 5 speed with 136,000 miles on it. Right after he had his spark plug wires changed, maybe it was just coincidence. He brought it back to the dealer and they said that all the sensors are ok. Anyone have any ideas? I just wondered if this was a typical problem that you guys have all solved already. I thought I would ask all of you guys to see if I can fix it and save him a few bucks. Thanks
"If you have tried to do something and failed, you are vastly better off than if you had tried to do nothing and succeded"-----(someone famous)-----
Old 02-12-2004, 08:00 PM
Bronco2 Bronco2 is offline
Re: Airbag light on after plug wire change???
So, are you telling me the dealer could not tell him why the airbag lite is on?
Old 02-13-2004, 06:30 PM
yes, they said that they just wanted to make sure one of them didn't disconnect a sensor or something, because he had them do a couple other things when he had the wires changed. He didn't want to pay the extra money to find out why it was on. On these newer cars, isn't the sensor just a box in the passenger compartment under one of the seats? or is it still bumper sensors?
Old 02-13-2004, 07:41 PM
The truck has multiple sensors,all identified by being bright yellow wiring connections-most techs will not disconnect these without disconnecting the battery and waiting for the caps. to discharge.(most vehicles). I think he is stuck with having it diagnosed to see where the problem is.
Old 02-15-2004, 07:59 AM
michelq michelq is offline
air bag system it is not do it your self you need to know what you are doing it is dangerous and expensive
Old 02-15-2004, 09:27 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Re: Airbag light on after plug wire change???
Excellent statement!
The SIR system is not a system to be messed with by the untrained. Incorrectly probing a wire or mishandling a componant can cause some serious and painfull consequences.
If the SIR light has come on, then the SIR system has seen a fault in the system.
There is a DTC stored to aid with diagnosis.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
1997 Clio Airbag + wiring diagram casahit Clio/Clio II/Clio III 1 12-03-2010 05:54 AM
Knock Retard!!! after plug wire change C man Park Avenue 4 07-06-2010 01:09 AM
Check engine light after plug and wire change krispy420 Ranger | Courier 4 10-25-2005 02:14 PM
98 stuck in 4wd low after plug/wire/rotor replacement JoshBarber Blazer 7 03-02-2005 10:40 AM
airbag light after rplacement shekky Malibu 4 12-05-2003 03:49 PM
