Old 06-30-2010, 04:08 AM
C man C man is offline
Exclamation Knock Retard!!! after plug wire change
I'm getting a P0325 code, Ignition ESC failure. This happened after I change my wires. The first time I accidentally mixed some wires up. Got the fixed and the my check engine light comes on. I have double checked several times to make sure I got the wire routing right. I changed one of the coils and put the old spark plug wires back on. Check engine light still on. Could this be a sign of a bad ICM. I don't understand how this could have happened. Should have left it alone but My gas mileage has dropped and the wires has 58k on them so I wanted to change them because one didn't clip to the coil pack.
Ideas please. on wits in suppose to go on a trip this week.
95' PARK AVENUE 168,000 MILES
Warning : Listen at your own discretion
Old 06-30-2010, 10:17 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Knock Retard!!! after plug wire change
After you put the wires on correctly did you clear the code?
Old 06-30-2010, 05:27 PM
Problem solved. And yes I cleared the codes with my scan tool several times. I went to the dealership, no more patience or time on hand. It ended up being the rear knock sensor wire grounding to the transmission half shaft. The tech said I probably did it when I changed my power steering pump lines because the wire was in the wrong place period. It probably has been grounding for a while intermittently which may account for the gas mileage drop. When I changed the plug wires I somehow made the wire have permanent contact with the transmission. I need to pay more attention to detail.
Side note, The tech thought that my wires were new and said that my car ran real smooth. I told them the were old and he said not to change them at all. I have duralast wires on them that I put on when I first got the car and they have almost 60,000 miles on them and only cost $19. Just putting in a good word for autozone parts, even though I belive in quality over price when it comes to cars. They are excellent for the price.
Old 07-02-2010, 05:37 AM
ZiggyPA ZiggyPA is offline
You know you can check the resistance of the wires to see if they are still good. The core deteriorates with time and this will give a higher resistance, which in turn gives a weaker spark and lower fuel efficiency.
Old 07-06-2010, 12:09 AM
Actually I did check the resistance of my wires and they were all in the 6-7k ohm range except for the one with the bad clip in the inside I couldn't get a reading on it.
