Go Back   Automotive Forums Car Chat > Renault > Clio/Clio II/Clio III
Old 10-21-2010, 02:14 AM
casahit casahit is offline
Question 1997 Clio Airbag + wiring diagram
Hi!
My daughter's 1997 Clio 1.4 has now problem with Airbag warning light. I checked the cables under seats and found one cable broken. I fixed this broken cable but this didn't fix the problem. Previous owner had replaced connectors below the seats with soldered joints. I measured resistance of seatbelt pretensioners by opening these joints and both seemed to be ok.
Does anybody have any glues how to fix this situation?
Also wiring diagram for Airbag / Seatbelt Pretension stuff would help a lot.
Does this 1997 model Clio have an OBD socket and are there any inexpensive programs to read errorcodes for Airbag system?
Help would be greatly appreciated
Marko
Old 12-03-2010, 04:54 AM
mechy1barry mechy1barry is offline
Re: 1997 Clio Airbag + wiring diagram
no diagnostic codes are stored for airbags,the data link connector
can be found under glove box-12 pin oblong.
light can only be put out with specialist equipment.
you could try removing/replacing f10 in fuse box,to see if the light goes out.
BE WARNED-WORKING ON THE AIRBAGS WITHOUT CORRECT INSTRUCTIONS
COULD MAKE THE AIR BAGS GO OFF!!.
Please Help 1997 Dakota Engine wiring diagram lilrogue78 Dakota 0 05-25-2010 02:45 AM
1989 S-10 Blazer Wiring Diagram 89S10Blazer S-10 1 01-07-2010 10:01 AM
i need an airbag wiring diagram streetfiremk Taurus | Taurus Wagon 6 11-03-2006 11:46 AM
1997 Grand AM Wiring Diagram 97 Grand Am Engineering/ Technical 0 12-13-2004 08:09 PM
1997 maxima radio wiring diagram needed teggie Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 07-15-2003 12:33 PM
Tags
airbag , clio , diagram , obd , wiring
