Old 02-05-2004, 05:42 PM
Akid Akid is offline
B18A1 ECU question
ive got a 93' B18A1, would I be able to run that motor off of an OBD-0 ECU?
Old 02-05-2004, 07:33 PM
91civicDXdude's Avatar
Re: ECU question
yes. get a 90-91 pr4 or a chipped 90-91 pm6 with b18a maps
Old 02-05-2004, 08:30 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
Re: ECU question
you could run it off a stock pm6 if you dont have money for a pr4 right now or something but the pr4 makes a biiig difference
2002 Acura TL Type S
1991 Honda Crx Si
Old 02-07-2004, 03:22 PM
The car has been running the 90-91 PR4 and i was having alot of problems so I thought that might have been the problem, but maybe not? so that 90-91 PR4 would be the better bet? The car is already wired OBD-0 but all my problems i was having with the car everybody thought it was an ECU problem, is there a chance the ECU is just bad? thanks for the help you guys!!
Old 02-07-2004, 03:40 PM
optimuscivic's Avatar
optimuscivic optimuscivic is offline
Re: ECU question
my car is wired 0bd0 with a 93 b18a head, so the 90-91 pr4 ecu should work. maybe its the distributor. that was one of my problems i had. also there could be bad wiring. what are the problems you are experiencing?
As American As A Burrito!
USDM 4 life!
Old 02-08-2004, 02:57 PM
Re: ECU question
if its an ECU problem, the ECU will either not work at all, or the car will run so horribly you cant drive it and the ECU will flash 1 long flash when you start it up, and possibly the light will stay on forever..
ECU question soul180 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 7 05-29-2004 11:57 AM
dohc zc ecu questions, 89 integra ecu any problems? OneSikCRX '88 - '91 Civic | CRX | Wagon | Shuttlee 2 09-22-2003 08:47 AM
Ecu Question!!! Phat_Si '71-'87 Civic | CRX 9 07-30-2003 10:33 AM
a 96-98 Hatch w/ 3rd gen Integra GSR engine..ECU question XaznPKdogX '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 02-10-2002 03:42 AM
ECU question civicNoS '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 01-17-2002 09:06 PM
