Old 02-05-2004, 02:42 PM
dongta dongta is offline
Unhappy Need help with Amplifier, Capacitor, & Battery connection
Hi all,
I really need help to correctly & safely connect the capacitor to the battery and the amplifier. I followed the instruction came with the cap., fully charged the cap. with the bulb (the battery's neg. terminal is currently disconnected, cap's neg. terminal is grounded). As soon as I removed the bulb/resistor, the cap's power level is decreasing before I have a chance to connect the battery's neg. ternminal. Any help from anyone how to safely connect the capacitor to the battery and amplifier without any explosion are greatly appreciated. Does the capacitor have to be fully charged (with the power remain) when bulb/resistor removed?I'm new to car audio and desperately need help. Thank you very much guys.
Old 02-07-2004, 08:44 AM
GCguy2169 GCguy2169 is offline
Send a message via AIM to GCguy2169
I'd say let the power go down, hook everything up the way you had it, then pour the music. Your cap should start getting power to itand the volts should either level off, or they should increase, depending on music loudness etc. It's either this of your cap is junk, what kind is it and how many farad?
Old 02-08-2004, 08:13 AM
Also, try upgrading your Ground connections.
Old 02-08-2004, 07:35 PM
Thanks GCguy2169,
The name for the Cap is VOODOO, and it's 1.2 Farad. I bought it on Ebay and it looks very professional. The 4 ring terminal that came with it are huge and platinum plated. I think it drained through the amp, but I will try to install the way you suggested. The installer at BestBuy said that with a 1600 Max Watts Amp, I might not need a Cap, and he was right. While waiting for help at AF, I tried to install without the Cap and the "Bass Mekanic" cd sounds beautiful. Ground location is where the BestBuy installer initially grounded my audio stuffs. Thanks alot for your help man. Have a nice day.
anyone with a 4.0L: need help with wiring plug connections and wire colors randy78 Cherokee 0 08-14-2009 04:12 PM
Need Help With Capacitor AngryBeargrrr Car Audio 7 09-21-2008 09:30 AM
94 Century 3.1 Need help with battery removal Just Ellen Century 5 03-14-2006 07:51 AM
Need help with battery issue scottiebigs Jetta/Vento/Bora 1 06-04-2005 05:14 PM
Need help with battery drain flat-top Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 5 04-05-2005 10:16 AM
