Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 05-29-2005, 08:12 PM
scottiebigs scottiebigs is offline
Send a message via Yahoo to scottiebigs
Need help with battery issue
I have a '96 Jetta GL. I disconnected the battery to do some work inside the door panel. When I re-connected the battery, the car would not start. When I turned the key in the ignition, the anti-theft mechanism went off (all lights blinking). I shut off the alarm by locking/unlocking the doors, but when I tried again to restart the car, again the anti-theft mechanism went off.
I shut off the car, let it sit and when I came back to it, when I unlocked the door, the interior light blinked on and off at first before coming on solid. When I tried to start the car this time, the ignition clicked but would not turn over.
Any idea what the problem is? Does the battery have enough juice?
Old 06-04-2005, 05:14 PM
ingrdo ingrdo is offline
DUUUUUUUUUUUUUUUDEEEE! How did you fix the problem?? I've had the exact same thing happen and am so irritated that blowing up the car is an appealing option!!
Here's what I posted yesterday. "I've got a not-so-nifty (only b/c i'm ticked off) 96 Jetta GLS w/ just over 80K miles. She's been neglected for a bit and I've finally decided to sell. Yesterday, I put in a spanking-new battery and she started perfectly well. No problems at all. Gave her a quick wash before thunderstorms and put her in the garage. This morning wanted to pull her out to finish cleaning her up and she wouldn't start. I checked the battery connections and fixed the loose positive. However, before I could try to start her, the @*(&*!^&@*^ alarm started. It would not stop when I try to turn her over. In fact, the car will not start at all now but the alarm will not stop. So, before I blow up the garage (which would be really bad b/c it would take out my hubby's MGB) in frustration, will someone tell me 1) if there is a way to bypass or disengage the alarm system and 2), any hints/fixes to get her to start again? Again, there were no problems yesterday. Once I replaced the battery, the alarm started and I turned the key, and viola(!), perfect car. Now, nada!! thanks a bunch ahead of time!!"
Any help you can give me is fantastic!!
Thanks.
