Old 09-17-2008, 10:50 PM
AngryBeargrrr AngryBeargrrr is offline
Exclamation Need Help With Capacitor
so recently i bought a new 1,800 watt amp and i have a 1.5F capacitor it worked before on my old 750watt amp but now that i hooked the new one up the capacitor is getting power because all the light are on but its only reading 00.00 on the charge and because of that my subs wont work so does any one know whats wrong with my capacitor if i just hooked it up wrong or if its broke, please help me out anyone
Old 09-18-2008, 12:01 AM
Galuple Galuple is offline
Re: Need Help With Capacitor
Did you remember to charge up the cap with a resister first?
Old 09-18-2008, 12:05 AM
it was charged all the way when we first hooked it up it worked for about a minute then it went blank and read nothing but 0's
Old 09-18-2008, 12:15 AM
Scrapper Scrapper is offline
AF Premium User
and you checked all fuses? even the one's that is suppose to shut it down before blowing fuses or speakers or amp?
Old 09-18-2008, 12:19 AM
ya i checked the fuses in the amp and the main fuse that hooks up from the battery to the cap
Old 09-18-2008, 12:26 AM
AF Premium User
you may have to go with a higher amp alt?
Old 09-18-2008, 06:13 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
You connected something up wrong, please tell us exactly how all the wires on the cap are connected.
Old 09-21-2008, 09:30 AM
MotoAce51 MotoAce51 is offline
Note: The cap will slowly drain even without use. When it is taken out of the old system you need to short the circuit and connect the + and - of the cap together to drain it completely. Then you can re-charge the cap and you should be good to go. I ran into the same general problem once and thats what worked. It took a lot of research but there are a lot of people who have that problem.
Also you may need a bigger cap. You want 1farad per 1000W you are almost at 2000W so you should theoretically have a 2 farad cap. Although this wouldnt cause your problem.
