| Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines. |
Need help with battery drain
I have a 96 Maxima. The battery is good and alternator is charging at 14V. When the car is off there are two circuits in the engine comartment fuse box with 12V pulling on them: the battery/ign fuse and the power window fuse. Any ideas on how to better isolate the problem?
Re: Need help with battery drain
Check each fuse with an ammeter (current setting on a multimeter) with the car off. Anything with a significant current draw is your culprit.
SCREIST in South Central PA |
Battery is 60Ah =ampere hours If you measure 1 amp current draw, that means you have 60 hours and then battery is totally dead. At 48hours maybe no start any more... Very simple math: 1A x 48 hours is 48Ah 60 Ah minus 48 Ah leaves 12 Ah for startup. From this one can see that 0,5A current draw is about top limit, or bigger batt is needed. I think problems start is draw is more than 0,2A - 0,3A. ------------------------------------------------------------- Take one suspect circ fuse off at a time for overnight. The one causing prbl drain, should be inspected... 1. What is batt voltage 1 hour after you stop? 2. What is batt voltage in the morning? 3. What is batt voltage when u start?
. Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507 ![]() There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14 |
Re: Re: Need help with battery drain
It does drain the battery overnight, in fact it will drain the battery in an hour so much that the engine will turn over a few times when starting, but it's not strong enough to actually start the engine.
Re: Re: Re: Need help with battery drain
1. How much is voltage att batt while idling 2. What is voltage when you stop engine 3. What is voltage ½ hour after you stop engine 4. if you take batt terminals off at [2.], is there any difference at (3.) 5. While inserting batt terminal back on, is it sparking liberally? Healthy battery dies with all lights on in 'bout three hours. Devices capable of sinking more energy are starter and shorted alternator (one hour drain). Its either of them, or your batt is not full in the beginning.
