Old 01-31-2004, 08:23 PM
Delmo Delmo is offline
Unhappy 2001 Stereo Problems
Just got a 2001 Tahoe, and I noticed some problems with the stereo. It has pretty bad reception and the Speed-Compensated Volume (SCV) feature also doesn't work. It just has the basic Delco single cd stereo, however there was a 10-disc sony added. Is reception a common problem with this model or is it likely to be affected by something else?
The car also has an remote starter. So I am not sure if adding one of those things might have screwed up the wiring.
Any suggestions on what to check ?
Any help would be greatly appreciated....
Thank You !
Old 02-18-2004, 12:15 AM
Blazin56 Blazin56 is offline
Re: 2001 Stereo Problems
If your rca's for the cd changer are next to the antenna, this may cause some distortion due to the amount of power generated from the rca's
Old 04-01-2004, 08:42 AM
Gauchoy2k Gauchoy2k is offline
What is in it now the delco or the sony. Do you have onstar? even if it's not in use. Is the bad reception on the radio or cd play?
'99 Neon Highline Stereo Problem BarneyMobile 1st Gen 95-99 4 02-24-2010 07:50 AM
2001 Chevy Cavalier Coolant System Problem getwilde Cavalier Problem Diagnosis 0 09-18-2009 06:43 PM
Hooking up a Scosche FM Modulator to a factory Chevy Prizm 2001 stereo? Merth Car Audio 1 08-01-2008 06:00 PM
2001 Stereo switch... wildwinky Cavalier 2 05-31-2004 05:03 PM
2001 Camry Stereo Problems Raveen69 Camry/Camry Hybrid/Vista 3 11-18-2003 06:24 PM
