Old 01-29-2004, 10:38 AM
jwbow jwbow is offline
timing belt procedure
Hi everyone,
New to the forum and need some help. Getting read to change the timing belt, aux. belt and tensioner on my 92 talon turbo. I have the factor procedure but do not have the tensioner tool. I have seen an article on how to set it without the tool but have been unable to locate it. Anyone know where I can find it.
Thanks,
John
Old 01-29-2004, 01:15 PM
MrZ's Avatar
MrZ MrZ is offline
Re: timing belt procedure
jwbow;
That tool sure would be nice, but I've never used it. I've changed the belt twice, and have done it by feel both times. This may take a couple of times to get it right.
I gripped an allen wrench in a pair of vice grips, inserted the end of the allen wrench in one of the pulley holes, and just applied pressure to put tension on the belt and tightend the bolt. Of course you need to do this with the tensioner plunger retracted and held in place by putting a small allen wrench through the hole in the side of the tensioner.
One you have the tensioner pulley tight, you pull out what ever you used to hold the tensioner plunger retraced, then rotate the crank around twice. At this point you check the clearance as indicated in the factory procedure.
I personally set mine for the minimum clearance. I think it just makes sense to do that, since the belt will stretch a little when it is breaking in.
Let me know if you need a bit more detail in that explanation.
Mark
Old 01-29-2004, 05:21 PM
rambur's Avatar
rambur rambur is offline
Send a message via AIM to rambur Send a message via MSN to rambur Send a message via Yahoo to rambur
http://www.vfaq.com/index-main.html is your friend. Timing belt procedure is under the "engine" section.
Old 01-30-2004, 04:45 AM
MrZ's Avatar
MrZ MrZ is offline
rambur;
Hey, that's a great link! I've got some lunch time reading now!
Mark
2000 Mirage 1.8 Timing Belt changeout Mangoacn Mirage 0 12-18-2009 08:51 PM
Timing belt walk HELP! 91TSi_ Engine, Transmission and Drivetrain 13 10-15-2009 02:47 PM
Timing Belt kp055174 Accord/TSX/Accord Hybrid 2 07-27-2009 12:00 PM
timing belt and water pump :( cobraprince 3000GT/Stealth 17 07-09-2009 03:28 AM
How to change timing belt? RainSpirit44 SVX 2 03-25-2009 04:30 AM
