Old 01-26-2004, 02:18 PM
switched switched is offline
best spark plugs??
i have a 1999 base model 5speed and will be supercharging it with a kit from thomas Knight (www.boosthead.com) very soon and was wondering which aftermarket spark plugs you guys would recomend that i buy.
i've heard NGK platinum's or Iridium's are some of the good ones, but what do you think would work best for me? -thanks
Old 01-29-2004, 06:05 PM
Igovert500's Avatar
blue + red light magnet
Re: best spark plugs??
NGK's platinums are the popular choice of most, I believe Denso is another popular brand. Either should work fine. Iridium's claim to require less voltage to spark, to burn more fuel in the cylinder, the ability to spark leaner air/fuel ratios, and last longer. As well, they are more expensive. Many use the NGK platinums on their twin turbo setups and they work great, so they would be fine with your supercharger.
Old 02-03-2004, 01:05 PM
mitsu-hsx mitsu-hsx is offline
me and most other people with tt's run copper plugs. ngk r's at .032 gap if you have stock ignition. otherwise some people have problems with spark blowout with iridiums and platnums. if you run low boost you might not have any problems
Old 02-03-2004, 04:53 PM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
If you plan on going at a high boost, definitely go for a set of NGK copper spark plugs. They are one step colder than stock plugs. I gap mine at 0.028" to make it easier on the ignition to keep a strong spark going.
NGK Platinums are very good plugs for a car running boost lower than 12psi.
Old 02-15-2004, 01:17 PM
Igovert500's Avatar
How do coppers last in comparison to platinums? I am putting in a boost controller + gauge soon and am going to be boosting to 14.5psi until I get the money for more mods.
Old 02-15-2004, 02:47 PM
AcesHigh's Avatar
Prelude Guy
I change my every 10k miles.
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
spark plugs freakyfire05 ZX2 2 02-17-2009 11:03 AM
Best Spark Plugs and Wires for GS-R? PiNoY GsR RaCeR Engineering/ Technical 11 04-08-2002 12:05 AM
Best Spark Plugs and Wires for GS-R? PiNoY GsR RaCeR Integra 7 03-18-2002 12:46 AM
What are the best spark plugs for the G20? radicalG20 Engine 15 12-14-2001 04:53 PM
