Go Back   Automotive Forums Car Chat > Ford > ZX2
Old 02-16-2009, 05:09 PM
freakyfire05 freakyfire05 is offline
Question spark plugs
i pulled the plugs out of my 2000 zx2 and there is oil on them, quite a bit of oil somebody help please i just bought don't want things to go wrong already.
Old 02-17-2009, 05:27 AM
Davescort97 Davescort97 is offline
Escort guy
Re: spark plugs
You probably hust have a leaking valve cover. The oil is getting down into the spark plug area and you will have oil on the outside of the plug when you take it out. If the inside of the plug has oil like you desribe it would cause a rough running engine and smoke out of the exhaust. Is the oil on the inside? Yes, I'd worry. Is the oil just on the outside Yes, no worry. replace the valve cover gasket.
Old 02-17-2009, 11:03 AM
Re: spark plugs
it's just on the threads and outer area. thanx man what a relief the ass at autozone said that i was screwed no matter what should have known better than to listen to him
Tags
oil , spark plugs , valve cover gasket
