Old 01-26-2004, 01:29 AM
ceddy b. ceddy b. is offline
Question honda buddies a newbie brother needs help.asap!
i bought this 91 honda accord from a rinky-dink dealership. my car only came with one speaker. i tried to test all of the speaker outlets in the doors. for some reason my speaker isn't getting a response on the passenger side. honda buddies please help.
Old 01-27-2004, 12:42 AM
accordztech accordztech is offline
Send a message via AIM to accordztech
Re: cant figure out why speakers not playing
well first check the deck
is it aftermarket? if so go to the back and see if the wires are connected....
if its not then it may be the deck itself. if its a stock one they have a problem where sound turns off all the time, its due to the deck...i had this problem and replaced it with an aftermarket one and it was fine.
www.cb7tuner.com <---90-93 accord board
:for sale: left and right motor mounts for 4th gen accord. great condition
:strut bar, rear..no brace...
Old 01-27-2004, 09:59 AM
scarecrowdjinn scarecrowdjinn is offline
use a multimeter to trace the speaker wires and to test the speakers.
Old 01-27-2004, 03:22 PM
wagsaccordsir's Avatar
wagsaccordsir wagsaccordsir is offline
Maybe you should post your message here!!!
INTERIOR/AUDIO/SECURITY
There are more people that can help you there!
MY ACCORD ON KENWOOD'S PHOTO GALLERY
MY ACCORD ON CARDOMAIN
"CHEAP THRILLS"
I DON'T CARE HOW MANY SKY DIVES YOU'VE GOT. UNTIL YOU'VE STEPPED OUT INTO COMPLETE DARKNESS AT 850' WEARING 95LBS. OF EQUIPMENT AND 68LBS. OF PARACHUTE. YOU JUST HAVEN'T LIVED.
ARMY AIRBORNE!!!
Old 03-04-2004, 05:50 PM
Dan88LXI Dan88LXI is offline
Do this and check the Ohms of the speaker ( You can do this at the main harness for the head unit ) it should be 8-4 Ohms if it reads 0 then you would have a direct short which could cause your head unit to burn an output and the speaker would not work. If they all read 8-4 Ohms then I would suggest a new head unit. I know with my Accord when I replaced the speakers the rear 2 had lost all foam surround and made an awful fluttering noise. To test the head unit take your good speaker and put it to each of the four contacts from the head unit if the speaker works at each four points then your head unit is fine and you need new speakers. Good Luck DOOD
vibration cant figure out why tcfco2005 Cherokee 3 03-01-2005 01:18 PM
'89 Grand Am...wont start, cant figure out why. xkrittlex Grand AM 1 09-29-2004 04:04 PM
I still cant figure out the problem? DrewMrPimp Cherokee 5 06-04-2004 06:56 PM
B16 swap question I cant figure out mike123v Let's get Technical! 3 02-23-2004 02:24 PM
i cant figure out how to chop from pic to pic cusky ss Graphic Manipulation 4 08-10-2003 07:21 PM
