Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 12-27-2001, 01:53 AM
petzride's Avatar
petzride petzride is offline
hmm....camber questions..
alright.....I think it's time for me to get the camber kit.
I've learned the purpose of a camber kit, but I actually have no idea
where it should locate. Can anyone explain to me? And do I need to
take out my spring/shocks when installing them? Is it harder than
install lower spring and shocks. Cuz...I hope I'll be able to install them
myself too.
FULL OF S15~~
For sale: http://www.automotiveforums.com/vbulletin/t53308.html
Old 12-27-2001, 04:01 AM
CivicEx95's Avatar
CivicEx95 CivicEx95 is offline
Banned
Send a message via ICQ to CivicEx95 Send a message via AIM to CivicEx95
This is what one looks like for the front
This is where they go
This is what is looks like when installed
Check out my website for the fix for the rear
http://www.geocities.com/kingmantis81/rearcamber.html
Old 12-27-2001, 10:00 AM
highbrid highbrid is offline
i like that rear setup. did you have to use a camber kit for the front or is there a way to use bolts and washers in the front too? Just curious. Any place i can save money is good.
Old 12-27-2001, 10:36 AM
petzride's Avatar
Thanks.....that's really helpful....
so....I do need to remove my springs/shocks to install them, right?
And for the rear, the things I need are four 10x1.25 45 mm bolts and washers? that's all? I lowerd my car with prokit, and it lowered my car like 1.3. So how many washers do I need? two?
thanks~
FULL OF S15~~
Old 12-27-2001, 06:32 PM
jdmakkordman's Avatar
jdmakkordman jdmakkordman is offline
Send a message via AIM to jdmakkordman
no you dont need to remove your spring/shocks to install your camber kit but you will need an alignment right away. yes thats all you need for the rear i used two washers for my rear camber adjustment and im on sportlines so one may suffice for you but you have to check it
Old 12-28-2001, 12:41 AM
Dezoris Dezoris is offline
Mod for life
Send a message via AIM to Dezoris
thanks~
That is the fun part of the washer trick you may save money, on not getting a rear camber kit, but when you take it for an alignment most places will complain or charge you more because they have to add washers or remove them to get the camber corrected, it is not an exact science. You can find a rear camber kit for 120$ I would do it.
If you are strapped for cash then fine the washers will work
M.Sanew - AutomotiveArticles.com
Old 12-28-2001, 01:43 AM
petzride's Avatar
Thanks guys~~!!!!
yall really save me a lot of $$$$$....
I thought I would need camber kits for front and rear....
by the way, how much they usually charge for alignment?
thanks to all of you~~~
I appreciate it~~~~
FULL OF S15~~
Old 12-29-2001, 05:12 AM
Mod for life
Most places will charge you an hourly rate if you have a modified suspension, expect anywhere from 80$ to 190$
Old 12-30-2001, 12:38 PM
EliteAccordPH's Avatar
EliteAccordPH EliteAccordPH is offline
Thanks guys~~!!!!
I appreciate it~~~~
Full alignment runs between $40-50. Unless your place has a lifetime alignment plan for $99.95 or so then I would get that plan. It allows you 2 alignment checks per year for as long as you own your vehicle.
EliteAccord at Import Love
Old 12-30-2001, 04:56 PM
brads94accord brads94accord is offline
Send a message via ICQ to brads94accord Send a message via AIM to brads94accord
i got my alingment for 70$ he said it was gonna be 27$ a side to add more shims since i didn't have enough, so i had to go home and put more shims in then come back. (i used the washer method from that guys website) i bought a specialty products company adjustable camber kit for the front of my car and he didn't have to adjust it at all. i put it in the most correction place on it when i put it in, and my alignment print out said -0.1 on the left, and 0.0 on the right he never touched the camber kit. hahaha lucky guess for me.
representin old school ph since april 2001, formerly UGAbrad94Accord
311 rules!
94 accord lx
16" konig reigns
3.25 inch drop on sprints and bec-techs.
clears all around, intake, custom rear section exhaust
farenheight plasma xenon headlights
click for my website
Hmm some questions about buying a camaro... arachn1d Camaro Discussions 30 09-07-2005 03:57 PM
Camber question w/pic lithod02 Wheels/Tires/Suspension 10 07-16-2004 09:51 PM
Camber question w/pic lithod02 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-14-2004 03:25 PM
Stupid A$$ Camber question... dssmax '88 - '91 Civic | CRX | Wagon | Shuttlee 2 06-20-2004 12:27 PM
camber question jam4484 Tires and Wheels 6 03-31-2003 06:50 PM
