| Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive. |
I just got this 93 Civic DX Coupe and it has Ractive Coilovers(sleeves). It needs an alignment to straighten out the neg. camber. How do you tell how much it has been lowered from stock, is there a way to measure from the ground to center of wheel or top of the rim? I am riding on 13" steelies for now till I get so more money. Reason I want to know how low it is, cuz I need a camber kit. Not sure which kind for my height of car. I have seen the couple different kinds like wishbone style(Skunk2) and adjustable balljoint(SPC). Which is better for a really low car, and which brands? I want to go as low as possible and still be able to get a jack under it in case of a flat.
Pic of car ![]() TIA
http://www.freegizmos.net Last edited by lithod02; 07-16-2004 at 09:50 PM. |
Re: Camber question w/pic
those tires must rub teh iner fenders so much when u turn
ive got manuals 92-95 civic 96-98 Civic clicky here clicky here WTB:92-95 EX/SI cluster w/tach FS:*NEW* 92-95 civic coupe black floor mats(4). pm me for pics or offers |
not a bit, these are 13" steelies with 165/60/13
http://www.freegizmos.net |
stock ride hieght on my 9 dx coupe is 11-11.5 from center of wheel to ground. im on 17 inch rims
hrmm, so there should be a way to figure out what stock height should be on 13's.
Thanks for the info
Go to a Honda dealer and ask for the correct manual, in there you can find the height spec's. Even better buy your own - www.helminc.com If you plan on working on your own car then a FACTORY repair manual is a MUST!
Camber Changes
If you lower your vehicle one inch front camber can change by approximately -.75 degree. By lowering a vehicle two inches your front camber change will be approximately -1.50 degrees. When you lower a vehicle three inches you will change front camber approximately -2.50 degrees. Rear Camber also changes, but not as dramatic as the front. The above rates are an average, and may be different +/- for your vehicle. skunk 2 has camber kits that are +4\_4 and your rear camber is less than you front and if you want to be ghetto just use washers on the back It will work just woulnt use it myself
and for your car to be leagal the headlights have to be 22 inches off the ground my car has about a four inch drop and the headlights ar 18 inches off the ground
Re: Re: Camber question w/pic
![]() You need to measure from the fenderwell to the ground or the front lip to the ground.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!Autocross Help Page Buy my Civic parts! |
Re: Re: Re: Camber question w/pic
From the front lip to the ground is 6 inches. That is how it is now, not in the picture, I had to raise it to keep from wearing the tires out so bad.
Bought Skunk2 camber kit for the front and Ingall's for the rear. Will post pics after I install them next weekend.
