Old 06-20-2004, 06:31 AM
dssmax's Avatar
dssmax dssmax is offline
Arrow Stupid A$$ Camber question...
O.K.
I have done my searching and I'm just about as lost as when I first started.....
I have H&R Race Springs and KYB's its 2.25 in the front and 2.0 in the back, (although the front looks higher, or maybe its that damm Kicker VR comp box in the trunk...)
I measured with a level and all 4 tires are in alittle inwards.
Can an alignment correct that alittle or at all?
Should I try to get a camber kit and install it before I bring it in to be realigned?
And if so what would be a good kit to get? Aslo my pocket book isn't that full right now so it would have to be at a fair price..
Thanks,
MAX
Old 06-20-2004, 12:11 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Stupid A$$ Camber question...
alignment wont fit camber. I would buy a camber kit off ebay. Read the discription and make sure it corrects +- 3*. Some of the cheep kits only correct 1.75* and are bisicly just shims and dont work well. I would put a camber kit on before aligning it so that the shop can do the camber also.
Old 06-20-2004, 12:27 PM
BullShifter's Avatar
Re: Re: Stupid A$$ Camber question...
Civics/CRXs have no factory camber adjustments, therefore aftermarket kits are required at least for the front. On the rear you can make it yourself with some longer grade 8 bolts & washers. http://home.earthlink.net/~civicex95/rearcamber.html - don't use cheap ass bolts as ahown on website, spend the $$$ for high strenght bolts. Suspension bolts are very strong for a reason.
I recommend Ingalls for the front & high strenght bolts or an Ingalls kit for the rear.
