Old 12-26-2001, 11:57 PM
JE123's Avatar
JE123 JE123 is offline
Help needed applying Bare Metal Foil
First, I tested it out on a bumper of one of my junked models and then I tried to apply it on the model I am currently working on. It did not turn out to pretty. There were wrinkles in it and I couldn't get them out. I had to scrape it all off. I want to be sure I know what I am doing before I attempt it again. I used a burnishing tool (suppost to get the wrinkles out) but it did not work. Is there a trick to it?
-Joshua
Old 12-27-2001, 01:49 AM
primera man's Avatar
"P-Man"
Cut smaller bits if you have to to go over harder bits of the bumper were it wrinkles.
Then Cut strips that will cover the main flat areas last. Try and tuck any overlay that you have behide the bumper so its not seen.
It doesn't really matter if you overlay some pieces onto others as it should polish up OK and not be noticed.
Press done fairly firmly when sticking it down as you try and mold it into place
View All My Models Here.
Old 12-28-2001, 11:38 AM
JE123's Avatar
Do you recommend going over it with some polish or clear coat afterwards?
-Joshua
Old 12-28-2001, 12:50 PM
Guiddy's Avatar
Guiddy Guiddy is offline
No! Leave it alone!
Old 12-28-2001, 01:40 PM
JE123's Avatar
Originally posted by Guiddy
No! Leave it alone!
Thanks
-Joshua
Old 12-28-2001, 02:30 PM
"P-Man"
Just use Tamiya wax to polish it up....nothing else
When to apply Bare Metal Foil? Jimmy'Z Car Modeling 3 09-28-2008 09:07 PM
Help with Bare Metal Foil! The_GLL Car Modeling 9 02-02-2007 08:43 PM
Need help: Bare Metal Foil issues Nutsforcars Car Modeling 3 08-23-2006 12:53 PM
Substitution for Bare-metal foil JE123 Car Modeling 15 05-11-2003 07:04 PM
Bare Metal foil nustad Car Modeling 8 03-20-2002 02:30 PM
