Old 12-23-2001, 03:11 PM
JE123's Avatar
JE123 JE123 is offline
Substitution for Bare-metal foil
Can you substitute aluminum foil for bare-metal foil? No stores in my area carry bare-metal foil so all I have to use is aluminum foil.
How do you put the aluminum foil on the piece without it tearing?
-Joshua
Old 12-23-2001, 04:08 PM
turbos86's Avatar
turbos86 turbos86 is offline
I would also like to know!
and will aluminum foil be good to put behind headlights and taillights?
Old 12-23-2001, 04:24 PM
primera man's Avatar
"P-Man"
I wouldnt want to use aluminum foil myself as i dont think you could mold it the same or polish it like BMF.
With BMF it is so thin it doesn't really matter if you do tear it as you can lay another piece over the top and you can hardly notice it at all. Plus being so thin it is hard to *wrinkle*....if you do , its very easy to smooth back out.
My only advice would be to try doing the backs of lights and see what it turns out like with Aluminum foil.
I may be wrong though. Let us know how you get on.
View All My Models Here.
Old 12-23-2001, 07:21 PM
modelfan1's Avatar
modelfan1 modelfan1 is offline
Send a message via AIM to modelfan1 Send a message via Yahoo to modelfan1
To cut Bare Metal Foil you need a brand new #11 Exacto blade ,just lay the knife on top of the foil and slide to cut it,thats how thin the foil is. There is adhesive on the back of BMF. Aluminum foil is alot thicker and would not conform to curves.
Old age and treachery will overcome youthful exuberance everytime !!
Old 05-11-2003, 02:10 PM
shieldwulf's Avatar
shieldwulf shieldwulf is offline
Where to purchase BMF?
Where can I purchase BMF and "Krystal Clear Glue" on the web? Thanks.
Old 05-11-2003, 02:17 PM
Integra14's Avatar
Integra14 Integra14 is offline
Send a message via AIM to Integra14
aluminum foil looks ok... heres mine..
64 Chevy 64 Chevy is offline
Another alternative that would work but not produce the best results is the silver gum wrapper. you can seprate the silver part from the paper backing and the silver foil will be sticky. It can be hard to seperate though and you would need a good, new pack of gum to elimanate wrinkes in the foil. But it is a good way to practice the skills of using BMF.
Why can't I think of any thing clever to put down here?
Old 05-11-2003, 02:21 PM
daggerlee's Avatar
I've heard people using Hershey chocolate wrapper too in the same way.
Another alternative I have heard is to purchase cheap Dollar store foil and 3M Sprayable Adhesive. Dollar store foil is generally very thin and 'crappy' for cooking, but thinner than quality aluminum foil. Spray the adhesive on, then use as desired.
Dan
Old 05-11-2003, 03:04 PM
irupp33's Avatar
irupp33 irupp33 is offline
Send a message via AIM to irupp33
also aluminum "tape" has a MUCH stronger adhesive and you would risk pulling off some paint when u go to remove the excess.
1991 Eclipse GS-T
Exterior: stock
Interior: Boost and A/F gauge, TV/DVD player, thats about it.
Motor: supra side mount, hard pipes, greddy type s, greddy profec b b/c, nology hotwires, 3 in. turbo back exhaust.
Wheels and tires: stock shitty fan rims with stock tires (no grip what so ever)
Old 05-11-2003, 03:13 PM
bah humbug's Avatar
What about alcad chrome paint, I've heard it's practically like chrome.
Or try those paints at hardware stores trust me the spray cans that have chrom caps are also close to chrome, not as close as alcad but if you can't find anything else go with that. Or you can try duplicolor chrome.
Old 05-11-2003, 04:27 PM
hirofkd's Avatar
hirofkd hirofkd is offline
Testor Model Master's chrome does a decent job for the bracket. It's not as convincing as BMF, when used for the bumper and exterior trim, but it's acceptable for the lights.
Hiroaki Fukuda
Old 05-11-2003, 06:04 PM
irupp33's Avatar
alclad2 chrome works well. looks better if you have a big job to do. but if you want to do headlight recess's its so much easier to use bmf. I hear ppl sayin they cant get it in there arear so why not get it online? http://www.plastic-models.com has it i think.
1991 Eclipse GS-T
Exterior: stock
Old 05-11-2003, 06:49 PM
daggerlee's Avatar
I agree, Model Masters Chrome Silver rocks! Never quite 'dries' though, always stays kind of sticky.
Dan
Old 05-11-2003, 06:50 PM
Is alcad II brush-on-able...or is it only used in an airbrush?
Old 05-11-2003, 06:57 PM
daggerlee's Avatar
Airbrush only...haven't tried without one, though I think Veyron says if you brush it on thick and heavy and quick, it'll look alright on small parts.
Dan
