Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 01-23-2004, 10:36 AM
how2lose101 how2lose101 is offline
Oil leaking from oil filter....PLEASE HELP
Need help here please!
I recently had my oil filter replaced because I had a small leak coming from it that was causing a BIG stink
This morning when I started my car I again have the same problem. Now, it only seems to happen when it's extremely cold outside. Could this be caused by BAD oil??? Could the oil be causing the seal in the filter to leak??? If so, would an oil change correct my problem?
Thanks
Old 01-23-2004, 02:20 PM
pcv pcv is offline
Try using 5W30 oil for the Winter. Do regular oil changes. Maybe the relief valve in the filter housing is gummed up.
NOTHING LIKE AN OLD CAR.
Old 01-23-2004, 03:08 PM
I do use 5W30 and I do get regular oil changes (every 5000 kilometers).
I just had the filter replaced because it was leaking and now the new one is doing the same thing after being installed 2 weeks ago.
Any other ideas would be appreciated, thanks
Old 02-23-2004, 07:19 PM
sunfire2.2 sunfire2.2 is offline
Re: Oil leaking from oil filter....PLEASE HELP
If it is the same mechanic, he might not tighten it enough, or, it could be that brand of filter. Try one of those. When it gets cold, if the filter isn't tight, the rubber seal will shrink and cause it to leak.
oil leak?????? freakyfire05 Accord/TSX/Accord Hybrid 11 02-22-2009 01:44 AM
Leaking from oil filter housing L8R_H8R Let's get Technical! 4 11-20-2005 03:28 AM
Oil Leak from oil filter adapter Jeeped Cherokee 2 11-17-2004 11:22 PM
5.0L oil leak, can't find it please help!!!! aaron5140 Thunderbird 8 07-14-2004 08:13 AM
CHANGING MY OIL FILTER {please help} D1RTCHASER Pick-Up 5 04-10-2004 05:24 AM
