Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-14-2005, 02:55 PM
L8R_H8R L8R_H8R is offline
Unhappy Leaking from oil filter housing
Leaking from oil filter housing, how do i fix it?!!
At the time, McLaren was racing successfully with Honda engines, and it seemed logical to approach Honda for an engine meeting Murray's requirements. But the Japanese declined, feeling that they could not spare the capacity to develop such a project.
Old 11-14-2005, 04:10 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Leaking from oil filter housing
the only way the oil filter seat is going to get damaged is if you knicked it with some weird way of trying to pull off the oil filter. you sure its not the oil filter itself? the valve cover? oil pressure sender? rubber ring on oil filter was oiled before installation?
not sure where the leak is coming from, go to your automotive repair shop and sak them to do a blacklight leak detector test. the dye they put in will make tracing your oil leak location stand out like a sore thumb. actually can be done on any mystery oil leak.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 11-14-2005, 06:59 PM
its not the oil filter, bcuz it was leaking before and its been changed. not the valve cover eaither. or the oil filter gasket, maybe the pressure sender. The only place round here is goodyear, tryna avoid them cuz they over charge. thanks for the help though i think im def. gonna check the pressure sender
Old 11-19-2005, 07:39 PM
tech. tech. is offline
does the car have an oil cooler? if so it will have an oring behind the cooler and the filter actually mounts to the cooler and the cooler mounts to th block. this could look like a filter leaking what kind of car?
Old 11-20-2005, 02:28 AM
i found out what it was, pressure sensor. thanks for the help though
