Old 02-17-2009, 03:09 PM
freakyfire05 freakyfire05 is offline
Question oil leak??????
I have a 91 accord that leaks massive amounts of oil but only when it is running at normal temp????? what is going on when it is off it doesn't leak. when it is warming up it doesn't leak I'm confused
Old 02-17-2009, 07:21 PM
KManiac's Avatar
KManiac KManiac is offline
Re: oil leak??????
Where is the oil leaking from?? Usually an oil leak from a running engine would come from an unproperly sealed oil filter, a leaking oil pump, leaking crankshaft seals (either front or rear) or a plugged PCV valve, which causes high internal crankcase pressures that force gases and oil out every weak seal or gasket.
"This car may be old, but it will still climb Kirker Pass at 110!"
1962 Chrysler 300 2-door hardtop/1964 Chrysler 300-K convertible/1964 Chrysler Newport 4-door sedan/1964 Chrysler 300-K hardtop with Firepower 390/2x1964 Chrysler 300-K hardtop/1964 Chrysler 300 convertible/1964 Chrysler "Silver 300-K" with factory 4-speed/1964 Chrysler New Yorker Salon/1980 Dodge D-50 Sport/1986 Lincoln Continental/1989 Honda Accord DX/1989 Lincoln Mark VII BB/1991 Dodge Shadow ES convertible
Old 02-18-2009, 01:33 AM
Re: oil leak??????
It's not the oil filter, pcv valve, or plug for sure haven't really checked much farther than that. The fact that it only leaks when it's warm makes me think it's the pump am i wrong ?
Old 02-18-2009, 09:15 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: oil leak??????
Well, it could be leaking from the pump. But with the engine running the pump is pumping oil. What area is it leaking from?
Old 02-20-2009, 01:24 PM
Re: oil leak??????
There's a belt that runs vertical on the drivers side of the engine next to the oil pan it appears to be leaking from some where around there definetly above where the oil filter sits if that makes any sense
Old 02-21-2009, 12:15 AM
mpumas mpumas is offline
Re: oil leak??????
There is a weep hole at the bottom of the timing belt cover. If it is leaking from there, it is probably the oil pump. If you decide to change the pump, this is a good time to change the timing belt and water pump unless it was done within the last 50k miles.
Old 02-21-2009, 11:26 AM
Re: oil leak??????
That seems viable. would it leak ALOT of oil very quickly if this were the case
Old 02-21-2009, 11:55 AM
Re: oil leak??????
I'm now having problems trying to figure out where it is leaking. In one post you say it is on the drivers side near the engine belts, on the other you mention above the oil filter. If it is above the oil filter, it may be coming from the oil pressuse sensor. In either case, it could leak alot of oil when the engine is running because it is under pressure. You got to crawl under the car and pin point the location. Spray down the area with degreaser and water to clean things up then look.
Old 02-21-2009, 03:22 PM
Re: oil leak??????
i'm not sure why your confused the oil filter is right next the belts
Old 02-21-2009, 07:58 PM
FrankVtec88 FrankVtec88 is offline
Re: oil leak??????
Belt faces to drivers side, oil filter is near belt on intake side (rear side of engine).
Old 02-22-2009, 12:39 AM
Re: oil leak??????
My apologies the leak is on the drivers side of the engine. i simply was trying to state how high up the leak was. in retrospect it doesn't very helpful
Old 02-22-2009, 12:44 AM
kris's Avatar
Re: oil leak??????
Hard to say really without getting in there. You have a couple of seals, as well as some plugs on that side that could be bad or working loose. It might entail a day of pulling things off to look. Just remember oil likes gravity. Just because it comes out on the lower end, does not mean it can't be leaking from the top end.
Tags
oil leak
