Old 11-14-2004, 05:35 PM
Jeeped Jeeped is offline
Exclamation Oil Leak from oil filter adapter
I recently noticed oil seeping heavily from the oil filter adapter that's mounted to the engine block. I've read in other posts that it may be a bad o-ring. How do you replace it? Is this a job that can be done by a DIYer? If so how? Alternatively, if I went to a mechanic, how much should I expect to pay for repair? Thanks for any advice given.
Old 11-14-2004, 05:45 PM
Dale Aeppli Dale Aeppli is offline
Re: Oil Leak from oil filter adapter
Hi, if you give me a holler at [email protected]---i'll send you info on the o-rings and a sheet telling how to replace dale year make and engine needed.
Old 11-17-2004, 11:22 PM
Saudade's Avatar
Saudade Saudade is offline
As Dale is implying (at least I think he is), it's a fairly simple job depending on your engine.
I have the 4.0L and had to pull the adapter off to change the motor mount. Apparently, an earlier owner had a leak and used permatex to stop it. I had quite a problem getting it off. Once off the seals were shot. I spent more time locating the seals than it took me to replace them.
Send Dale an e-mail. He'll hook you up!
