Old 01-21-2004, 11:16 AM
Father of Two Father of Two is offline
ABS light flashing - 1990 Silverado
I am the original owner of a 1990 Chevy Silverado and a few months ago the ABS light started flashing.
1 long - 8 short flashes.
My local chevy dealer told me that the 90 models were a little 'squirley' when it came to abs and showed me how to reset the abs system by unplugging the abs computer mounted on the master cylender. That stopped the light from flashing - but only for a few weeks. It has returned.
Anyone else had this issue?? What solved it??
I can't believe that a warning light goes off for no reason.
Thank you all for your responses.
Old 01-21-2004, 02:29 PM
RABarrett RABarrett is offline
Re: ABS light flashing - 1990 Silverado
I am not sure of the code relating to 18, but I have seen this condition exist. If you get me the code, we'll go from there. Ray
Old 01-23-2004, 10:17 PM
Ray,
The only code I have is the '18' from the ABS light. There is no OBD code stored. Any help that you can provide would be greatly apriciated.
...Leonard
Old 01-24-2004, 04:56 PM
billyklub billyklub is offline
I own a 90 Silverado (original owner) and just recently my ABS light started to flash and after a few months it now stays on all the time. My mechanic said to disconnect the connection and the light will go off. Does the light mean the ABS is no longer working or is the computer board just no good?
Thanks, Billy
Old 01-24-2004, 10:50 PM
homefree's Avatar
homefree homefree is offline
I would look to make sure that you don't have a leak. I had the same problem (1989 truck) and found a leak in the brake line going to the back of the truck. (it was rusted thru where it was held onto the frame)
Old 01-25-2004, 09:08 AM
billy2 billy2 is offline
I also have a 1989 k2500 with a blinking abs light. Unplugging the module only helps for a couple days. I have swapped the abs module with a known good one from a 1992 truck, still the light blinks. As a side note the speedometer intermitantly stops working. The dealer says its a bad cluster, but it has been doing this for 5 years and hasnt completly stopped working. Now what I am getting at is when the speedo quits the brake light comes on. Those anti locks work off the VSS (vehicle speed sensor) same as the speedo does right? Could this somehow be related? Does anybody elses speedo do the same thing?
Does anybody know where the VSS is on the transfer case and how the wires run up to the abs and speedo?
Thanks,
Bill
Old 01-26-2004, 07:13 PM
quaddriver quaddriver is offline
Send a message via AIM to quaddriver Send a message via MSN to quaddriver Send a message via Yahoo to quaddriver
ya'll need to hook up to an ABS friendly scan tool.
KH RWAL systems will reset if you pull the power connector, but if it comes back on, something is upsetting the 'puter
Old 01-27-2004, 07:16 AM
Mine does not set a computer code, just the abs light blinks, I am not shure its a code, rather just random blinks.
Old 01-27-2004, 09:13 AM
Re: Re: ABS light flashing - 1990 Silverado
abs codes are stored in a different location in a different 'puter, thats why you need a scan tool with ABS capability as it looks at a different pin of the ALDL
Old 01-27-2004, 07:02 PM
Is the ALDL the same as the DLC under the dash?
Old 02-17-2004, 04:25 PM
Docholiday Docholiday is offline
Docholiday []
Status: online
12-27-2003, 11:50 AM
Brake Light flashing (Post #1)
Recently, my park brake light on the dash of my '91 K1500 started flashing.....3 short flashes followed by a long flash. It must be a code of somekind. Any ideas anyone?? 1 long 4 short seems to be common
Report Post | IP: Logged
95 silverado abs light is on and smells like brakes joseriverasg Silverado 2 12-21-2009 10:15 AM
ABS Light flashing, no A/C, no power windows Goaliegirl Blazer 4 07-28-2005 09:18 AM
Battery & ABS Lights flashing-egines dies at times aroznos Rodeo | Passport | MU 1 06-09-2005 08:48 AM
97 S-10 ZR2 Brake and ABS lights flash I_Make_Ale S-10 4 02-22-2005 11:47 PM
ABS light flashing - 1990 Silverado Father of Two C/K 0 01-21-2004 10:47 AM
