Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 06-08-2005, 09:42 PM
aroznos aroznos is offline
Battery & ABS Lights flashing-egines dies at times
I have a 1998 Isuzu Rodeo S 2WD( 4 cylinder, manual transmission) When I drove it today the battery light and ABS light came on and everytime I stopped the engine died. It would start ok and the battery /abs lights flickered on/off until the next stop and the engine died again. I was able to make it home but am concerned if the problem is a bad alternator or the what ? I checked the voltage at the battery terminals at idle and 2000 RPM ( 14 - 15 Volts). It doesn't die everytime it's idling, seems to occur after driving near highway speeds a short distance.
I took my truck in and had them check the codes- odd thing, the only codes in there was a PO300-- Random/Multiple Cylinder Misfire. Not sure what this means but can't see how it relates to the battery light and ABS light blinking on/off and the engine just dying at times- I checked and a new alternator is 165.00 ( rebuilt), I hate to spend the money if that's not the problem-- Any Suggestions would be appreciated, I suspected the alternator but the voltages (above) seemed ok-- I am at wits end, any suggestions would be appreciated.
Thanks
Old 06-09-2005, 08:48 AM
Ramblin Fever Ramblin Fever is offline
Re: Battery & ABS Lights flashing-egines dies at times
What kind of spark plugs are in there? What's the mileage on them?
Isuzu's are volt picky vehicles, if they sense a weakness anywhere, they will act weird. Test your alternator under load, this is where it will show a fault on these trucks.
Word of advise, do NOT choose just any aftermarket alternator; needs to be an OEM alternator or you'll likely be eating them up every few months.
One thing I've learned about my Isuzu, they like high quality parts. But they last longer too.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
