Old 02-20-2005, 08:30 AM
I_Make_Ale I_Make_Ale is offline
Question 97 S-10 ZR2 Brake and ABS lights flash
Occasionally when driving my 97 S-10 ZR2 4x4, the heater fan will stop running, and the brake and ABS warning lights will flash quickly in sequence. This only takes maybe 2 seconds, then the fan comes back on, and the lights go off and stay off. It doesn't happen enough to be able to isolate the conditions that seem to trigger it. It seems like it happens mostly when I'm depressing the brake pedal, but I believe I had the cruise on a few times when driving about 35 mph too and it dropped the cruise, and I had to switch it off and on again to reset it. It stops just fine. The brake fluid appears to be full, and I haven't done any brake work for probably 6 months when I replaced the rear shoes.
Has anyone else seen this and have an idea what the problem might be?
Thanks!
Old 02-20-2005, 09:01 AM
ALMB~Nova ALMB~Nova is offline
Re: 97 S-10 ZR2 Brake and ABS lights flash
Thanks!
Sounds like a short somewhere (maybe in the abs wireing) Get a scan tool and check to see if it has any codes.
Old 02-20-2005, 11:36 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
an abs sencor could be going, im unsure of where its located, but my grandpas toyota coraolla had similar symptums untill the sencor eventually went out, they were 200 bucks for just the part
Old 02-20-2005, 02:29 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
That would cause the fan to die.
Dead short somewhere.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-22-2005, 11:47 PM
Thanks. I'll see if I can read any codes. That might help me narrow it down to a sensor if that's what's going. I'm open to other ideas as well.
