Old 07-09-2005, 11:05 AM
Goaliegirl Goaliegirl is offline
ABS Light flashing, no A/C, no power windows
I searched the past posts and didn't find anything that related to this problem. Hope someone can help!
I have a 97 Blazer LS that has the weirdest thing happen. The ABS lights and the Emergency break lights flash while driving. While this is happening I have no A/C or heat, the fan doesn't work, and I have no power windows. We have replaced wires and searched everywhere in the vehicle we can think off to find the problem.
This problem has stumped everyone that I have asked so far. If anyone has any advice/suggestions they would be greatly appreciated!
Old 07-09-2005, 01:15 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: ABS Light flashing, no A/C, no power windows
Chekc the fuse panel for a worn through wire.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 07-22-2005, 09:11 PM
dhblazer dhblazer is offline
window and AC problem
I had the same problem on our 1997 blazer. We had to replace the ignition switch in the steering column. The switch is not sending power to a relay under the dash that will make those things work. Beleive me I tried testing everything and this is the one thing that fixed the problem. Let me know if you get this fixed. Hope this helps.
Old 07-25-2005, 12:26 PM
BlazerLT's Avatar
AF -Advisor
Yea, the ignition switch would cause this, thanks for pointing that out.
Old 07-28-2005, 09:18 AM
Re: Re: ABS Light flashing, no A/C, no power windows
Yep....it was the ignition switch. My mechanic did a swap test just to be sure that it was the ignition switch. It got fixed and the heat wave ended. Thanks for all your help.
