Old 01-20-2004, 11:13 PM
Sam60 Sam60 is offline
Question 94 Sub with 350
any ideas on why engine sounds so loud in the cabin; like exhaust is not making it back to tail pipes; 94 350 all stock best I can tell with 190k; and if I might be so bold to ask a second question.... how do you change the bulb in license plate lights on these step up bumpers... wants to pop back in like it's spring loaded and can't get to from underneath.
Old 01-21-2004, 12:01 PM
Bremln Bremln is offline
Re: 94 Sub with 350
What sort of sound is the engine making? Does it sound good or is it knocking or anything like that? When was the last time it had a tune up?
Old 01-21-2004, 10:31 PM
Re: 94 Sub with 350
engine running fine just sounds loud inside front seat; exhaust used to growl so nice from pipes, now sounds like coming from under hood; could it be manifold gasket?
Old 01-21-2004, 11:07 PM
Re: 94 Sub with 350
i'm no expert, but that would be a good thing to check. maybe just stick your ear down as close as you can to the manifolds and see if you hear a leak in the exhaust. or just see if you can pinpoint any sort of loud noises.
Old 01-25-2004, 10:31 AM
Re: 94 Sub with 350
On further inspection, noise appears to be coming from fan shroud but fan is not rubbing anyplace; could it be a bad fan clutch? Any help on the step bumper license plate lights would be appreciated
Sub with Stock Radio on 00 GTP BigFig15 Grand Prix 4 09-23-2004 01:41 AM
Camaro with 350 GM crate engine or 240sx with sr20det? xXx Loki xXx Car Comparisons 4 01-28-2004 02:21 PM
First time Installing a Subs with Amp... Koper Stratus 1 07-16-2003 03:01 PM
stock sub with aftermarket amp hinggu Sentra | 200SX (USDM FWD) 0 07-27-2002 01:57 AM
