Old 01-20-2004, 01:18 AM
tke_chevy tke_chevy is offline
How to stop the chiming in an 03 Silverado
The chimes are about to kill me. It is so loud when you put the ignition keys in you want to hold your ears. Is there a way to stop the chiming without replacing the radio? Thanks in advance.
Old 01-20-2004, 06:39 AM
nchelseth nchelseth is offline
Smile Re: How to stop the chiming in an 03 Silverado
I also have a 2003 Silverado LT w/XM Radio. The chime loudness in mine can be adjusted via the radio. It tells you how in the owners manual.
Old 01-20-2004, 11:07 AM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
Chime Level Adjustment
The radio is the vehicle chime producer. To change the volume level, press and hold pushbutton 6 with the ignition on and the radio power off. The chime volume level will change from the normal level to loud, and LOUD will appear on the radio display. To change back to the default or normal setting, press and hold pushbutton 6 again. The chime level will change from the loud level to normal, and NORMAL will appear on the radio display. Each time the chime volume is changed, three chimes will sound as an example of the new volume selected. Removing the radio and not replacing it with a factory radio or chime module will disable vehicle chimes.
Old 01-20-2004, 12:13 PM
Re: Re: How to stop the chiming in an 03 Silverado
Are the only two options loud and normal? Thanks
how is the gas milage on the new silverados? BOTTLEDZ28 Silverado 2 07-22-2007 06:08 PM
How can I stop the BEEPING??! ScottysMom Taurus | Taurus Wagon 4 01-28-2006 06:52 PM
How do I disable the chimes? balboasdelight TrailBlazer | Trailblazer EXT 3 03-01-2005 08:39 AM
How Can I Stop The Seat Belt Beeping? CBSupersonic Engineering/ Technical 6 01-12-2004 08:12 PM
How can I stop the annoying seat belt beeping? CBSupersonic Accord/TSX/Accord Hybrid 5 07-28-2002 08:17 PM
