Go Back   Automotive Forums Car Chat > BMW > 5 Series
Old 01-14-2004, 04:12 PM
WindyCityBMW WindyCityBMW is offline
97 528 Speedometer Sensor Need Help
I have a 97 528. The speedometer and MPG gage have stopped working. I assume the sensor needs replaced......??
Also, the traction warning light and ABS warning light came on and stay on, occurred at the same time. Same sensor?
Anyone know if this is a doit yourselfer? Any advice?
Thanks a bunch
Old 02-07-2004, 08:57 AM
mrrick mrrick is offline
Re: 97 528 Speedometer Sensor Need Help
Did you find out what your problem was.
Old 02-07-2004, 11:59 AM
KC Ron Carter KC Ron Carter is offline
Hmm,
99% of BMW speedometer issues are the connector at the aft face of the differential.
Cleaning and using a petroleum based grease to seal fixes them all.
Later,
Old 02-07-2004, 03:33 PM
Re: Re: 97 528 Speedometer Sensor Need Help
I will try that first thing monday morning and let you know if that takes care of the problem, Thanks for your reply either way
Old 02-14-2006, 07:16 PM
odjangi odjangi is offline
hey man how you doin?
i was wondering if you ever found a solution to your "speedometer/mpg/dsc/abs/brake" lights coming on problem!
i have the same exact problem. please drop me a line and let me know what you had to do to fix it, and how much it cost you.
thanks a bunch
Old 02-27-2006, 01:35 PM
BAVARIANM BAVARIANM is offline
On that model, the speed signal is generated by the right rear speed sensor. Read the fault codes to verify. Could have more than one bad sensor, but only the right rear drives the speedo
95 Integra with VSS problems + more...need help! cwshifflett Integra 0 10-27-2010 03:42 PM
need help!!! with my k1500 Deviousk1500 C/K 1 05-16-2010 10:23 AM
'84 Trans Am G - Speedometer Problem, Need Help Identifying Part Fit4Demolition F-Body Problem Diagnosis 3 04-25-2007 11:31 AM
removing speedometer needles NEED HELP EagleFURY97 Off-Topic 13 09-02-2005 02:56 PM
broke sensor need help!!!! DjbabySqueak '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 01-24-2002 12:02 AM
